Put in SX/B 2.0 — Parallax Forums
Put in SX/B 2.0
UghaUgha Posts: 543
edited 2009-02-24 11:18 in General Discussion
So far I absolutely love 2.0. I just have a minor problem I can't be sure of.
I understand that this works:
temp1 var byte
temp2 var byte
temp3 var byte
array var byte(3)
temp1 = 5
temp2 = 10
temp3 = 15
put array, temp1 to temp3
But I had expected put to also work in copying arrays.
Example:
array1 var byte(10)
array2 var byte(5)
i var byte
for i = 0 to 9
array1(i) = i
next
put array2, array1(0) TO array1(4)
But it doesn't work for me... it just overwrites the first byte of array2 with $00
I think I understand that using an array's label is the same as using the first element of the array (array2 = array2(0)) in this case,
but how would I go about doing the above?
I can do a work-around with two counters and a for loop, but I love put so much that I'd like to use that if its possible.
Sorry if this is answered elsewhere or has a simple answer... I·just don't get it.
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2009-02-24 02:01
    This is the generated code
       732  010A  0CDA        MOV FSR,#array2                ;put array2, array1(0) TO array1(4)
            010B  0024
       733  010C  0204        MOV __PARAM1,FSR
            010D  0028
       734  010E  0CD0        MOV FSR,#array1+0
            010F  0024
       735  0110  0204        SUB __PARAM1,FSR
            0111  00A8
       736  0112  0C05        MOV __PARAM2,#(array1+4 - array1+0)+1
            0113  0029
       737  0114  0200        MOV __PARAM3,IND
            0115  002A
       738  0116  0208        ADD FSR,__PARAM1
            0117  01E4
       739  0118  020A        MOV IND,__PARAM3
            0119  0020
       740  011A  00C8        MOV W,--__PARAM1
       741  011B  00A4        SUB FSR,W
       742  011C  02E9        DJNZ __PARAM2,@$-8
            011D  0010 0B14
       743  011F  0018        BANK $00
    Looks to me it should work.
    regards peter
  • UghaUgha Posts: 543
    Strange... it must be something else in my code. I thought I had eliminated everything else and when I ended up using put array1, array2 it worked fine.
    I apologize for wasting your time.
