HB-25 Motor Controller Connections
I need to see an example of how the HB-25 motor controller can be connected in system.· I read through the manual, and I understand that I can connect BRW to the development board using an LCD cable connector, and M1 and M2 connect to the motor.· I'm assuming that Vin and GND can be connect to a 9V battery.· Is that right, or do these two also need to be connected to the development board?
Connect + and - to your motor battery, not your BOE or other uC board.
Connect the three wire servo cable on the outside group of headers, following the color labels (b= black, w = white).
Jax
If a robot has a screw then it must be romoved and hacked into..
I'm not in NYC but any Hobby RC store will have them.
Jax
If you have any old pc's most of the cables used the .1 spacing and with a little work you can get something going.
The cables from Paralax are a good deal - I didn't know until after I hacked up the servo extenders.
