HB-25 Motor Controller Connections — Parallax Forums
Joe33Joe33 Posts: 8
edited 2009-02-24 00:01 in Robotics
I need to see an example of how the HB-25 motor controller can be connected in system.· I read through the manual, and I understand that I can connect BRW to the development board using an LCD cable connector, and M1 and M2 connect to the motor.· I'm assuming that Vin and GND can be connect to a 9V battery.· Is that right, or do these two also need to be connected to the development board?
  • SRLMSRLM Posts: 5,045
    edited 2009-02-20 07:12
    You connect the M1 and M2 to your motor leads.
    Connect + and - to your motor battery, not your BOE or other uC board.
    Connect the three wire servo cable on the outside group of headers, following the color labels (b= black, w = white).
  • GWJaxGWJax Posts: 267
    edited 2009-02-21 00:25
    Also make sure you connect the ground (GND) connection to your Boe-Bot and any other power source groound you use, else the circuit will not work with your code from any Stamp or other MCU..
    Jax
    If a robot has a screw then it must be romoved and hacked into..
  • PropabilityPropability Posts: 142
    edited 2009-02-21 00:56
    The ground connection will be established with the 3 wire connection of the lcd connector so that is all that is neeed for coms between the BOE and the HB-25.
  • Joe33Joe33 Posts: 8
    edited 2009-02-21 18:31
    Perfect.· Thanks for clarifying that for me.
    edited 2009-02-23 22:25
    Anyone in the NYC area know where I can buy a servo cable. I know I can online, but I was hoping there was a store somewhere. Radio Shack didn't have any.
    edited 2009-02-23 23:30
    Joe33 said...
    I'm not in NYC but any Hobby RC store will have them.
    Jax
    Most servo cables are extenders with a male and female ends. What you need are ones with both ends female ( I went to a hobby store looking for them and got a weird look from them-they even went online looking for them). I ended up for the time being hacking two together.
    If you have any old pc's most of the cables used the .1 spacing and with a little work you can get something going.
    The cables from Paralax are a good deal - I didn't know until after I hacked up the servo extenders.
