Twin motor rc mixer need... any suggestion!!!
I am currently working on a remote control airplane with twin electric engines. I would like to control the amount of thrust to each engine by mixing the throttle with the rudder channel. I believe the best place to do this is between the radio receiver and the motor esc, which would require two inputs and two outputs. I have no previous experience with programming. What are my best options for learning and creating this mixer?
- Stephen
One way to follow that advice is to write it out in words.· This is OK but is slow.
Anothe way is to create a simple flow chart -- which is just a shorthand form of those instructions for the beginner.· I always do a flowchart for any program that I expect to take more than ten minutes to write.· It saves me untold heartburn.· Usually it's just scribbled on a palimpsest -- I'm always running out of paper -- but it makes all the difference in the world.
· -- Carl, nn5i@arrl.net
Post Edited (Carl Hayes) : 2/20/2009 5:10:34 AM GMT
I am building a V-22 Osprey and the variable motor control will be mostly for hover mode to balance and manuever the airplane.
Should be awsome if i can get it working.
I would think this would be feasible with a BS2 if it is feasible at all.· The Marine Corps had doubters, but the V-22 does fly.
Another alternative is to use a mixer like that used for flying wings or V-tails.
As for the V-22 model, I am sure you will need at least a roll gyro. Great Planes makes a small brushless motor intended for foamies called the V-Pitch. Using a pair of those with the speed governed, adjusting the pitch instead of rpm would probably work better. You can also reverse the blades on one so that the props are counter-rotating. In that case you would not be mixing the throttles at all.
Rich H
