No Basic Stamp Found
The existing programs who are loaded on the 2 boebots I have are
working fine and are communicating over the serial port.
When I connect them using a usb to serial converter I can open a debug
window in the basic stamp editor and I can see correctly information
coming from boe-bot and I can send commands to it over serial.
When I try to upload any program to both of them I am getting No Basic
Stamps found even if the specific com port used if being checked and
both Loopback and Echo are NO.
Please also note that another proof that the serial to usb adapter
works fine is that I used this adapter in combination with a null
modem cable to update the firmware of mt dreambox (my satellite
receiver) and worked fine.(so in my understanding the adapter is fine,
I can send/receive info over serial to the boe-bots but I can not put
new programs on them since I am getting the message No BASIC Stamps
found
I have two BS2 stamps and one BS2p. I tried this will all stamps (which currently have a different program loaded on them) on two different computers. I even tried restarting the computers.
Please help! Thanks very much for your time!
found
http://www.parallax.com/Store/Accessories/CablesConverters/tabid/166/CategoryID/40/List/0/Level/a/ProductID/379/Default.aspx?SortField=ProductName%2cProductName
Dave
Dave Andreae
Parallax Tech Support·
The fact that your "dreambox" can be updated is no proof that the DSR, RTS, and DTR signals are working properly. Some download protocols do not use these, but the Stamp requires them to work properly. The Stamp debug window also does not require that these signals work.
