Robolympics Medal — Parallax Forums
Robolympics Medal
UghaUgha Posts: 543
edited 2009-02-05 22:09 in General Discussion
Is there any reason why the Robolympics medal uses an incredibly rare and hard·to get battery (CR123A)?
Does it require the battery for any special reason or can any 5-6 volt source work for it?
Edit: I moved this from the SX forum because I figured this one's better suited for this question.
  • FireHopperFireHopper Posts: 180
    edited 2009-02-02 23:40
    123a? thats a common battery for cameras..
    its 3 volt isn't it? the 223 is the 6 volt right?
  • UghaUgha Posts: 543
    edited 2009-02-02 23:58
    I've tried two shops with no luck on the CR123A yet.
    It's 3 volts, yes, according to wikipedia... but there are two of them in the medal.
    I can swap it over to AAs but I needed to know if there was any special reason the 123As were used... does the circuit require exactly 6 volts? Or is there
    some feature of a lithium battery that I don't know of that it needs?
    In other words, I'm just being cautious.
  • Cole LoganCole Logan Posts: 196
    edited 2009-02-03 00:03
    I found them at walmart the last time I got batteries last x-mas for my moms camera.
    edited 2009-02-03 00:05
    Ugha said...
    if you swap to AA's you will need 4 aa's instead of the 2 123's
    and yes. radio shack and walmart and CVS and target and such should carry them
    edited 2009-02-03 00:11
    I figured I'd need the four AAs... thanks for the feedback... I'll start hacking right away!
  • RDL2004RDL2004 Posts: 2,554
    edited 2009-02-03 05:48
    You won't easily find CR123 batteries if you live far from civilization, but they are fairly common. Walmart stocks them (look in the photo dept.), and any other large chain including drugstores such as Walgreen's, Radio Shack, etc. should have them (they do tend to be very over-priced in some stores though).
    - Rick
    edited 2009-02-03 12:59
    I went ahead and disconnected the battery holders on the back of the medal and soldered on some wires.
    I have a 6volt wall wart I can use for programming (Once I find something I can scrap for a female barrel-jack) and if I ever need to, I can use 5 AA rechargables
    to reach the 5.5v or so the thing seems to require.
    On a side note... Rechargables, when freshly charged, read at higher than 1.25v. Its actually enough to run a BOE or SX tech board on 4 for about 5-10 minutes!
    Ya learn something new every day [noparse]:)[/noparse]
  • wmroewmroe Posts: 3
    edited 2009-02-04 22:19
    I just bought a kit that has a Medal included. I looked at it for a long time, trying to figure out the battery.
    I checked the Parallax website, only to find that discontinued items are not supported... [noparse][[/noparse]Bummer]
    I had read in "Nuts and Volts" that the forums are a great place to get info, so... Here I Am... [noparse]:)[/noparse]
    Thanks, Ugha, for the battery number and specs.
    I'll get some at Wal-Mart tomorrow, then... IT'S PLAY TIME... [noparse]:)[/noparse]
    W. Mark Roe
    edited 2009-02-05 22:03
    What I ended up doing was desoldering the battery holders and run the thing off the +5volts on a BOE. It can also safely run on a regulated 6volt supply.
    At least those are my experiences.
    Would a 5pack of batteries for $4.30 do?
    http://www.dealextreme.com/details.dx/sku.5639
    And yes, that includes shipping...
    (They have rechargeables in the same size, too)
    Don't visit my new website...
