Robolympics Medal
Is there any reason why the Robolympics medal uses an incredibly rare and hard·to get battery (CR123A)?
Does it require the battery for any special reason or can any 5-6 volt source work for it?
Edit: I moved this from the SX forum because I figured this one's better suited for this question.
its 3 volt isn't it? the 223 is the 6 volt right?
It's 3 volts, yes, according to wikipedia... but there are two of them in the medal.
I can swap it over to AAs but I needed to know if there was any special reason the 123As were used... does the circuit require exactly 6 volts? Or is there
some feature of a lithium battery that I don't know of that it needs?
In other words, I'm just being cautious.
if you swap to AA's you will need 4 aa's instead of the 2 123's
and yes. radio shack and walmart and CVS and target and such should carry them
- Rick
I have a 6volt wall wart I can use for programming (Once I find something I can scrap for a female barrel-jack) and if I ever need to, I can use 5 AA rechargables
to reach the 5.5v or so the thing seems to require.
On a side note... Rechargables, when freshly charged, read at higher than 1.25v. Its actually enough to run a BOE or SX tech board on 4 for about 5-10 minutes!
Ya learn something new every day [noparse]:)[/noparse]
I checked the Parallax website, only to find that discontinued items are not supported... [noparse][[/noparse]Bummer]
I had read in "Nuts and Volts" that the forums are a great place to get info, so... Here I Am... [noparse]:)[/noparse]
Thanks, Ugha, for the battery number and specs.
I'll get some at Wal-Mart tomorrow, then... IT'S PLAY TIME... [noparse]:)[/noparse]
W. Mark Roe
At least those are my experiences.
http://www.dealextreme.com/details.dx/sku.5639
And yes, that includes shipping...
(They have rechargeables in the same size, too)
Don't visit my new website...
