Needing help find a company(s) to order small quanties for wire harness
I am looking to purchase some kind of 10 wire male / female connectors that can be soldered to a PCB. The other connector needs to have the contacts to connect wires. With an extremely limited budget, I need to be able to order small quantities. I am also looking for inexpensive DIP Cat-5 female connectors. Cheaper is better [noparse]:)[/noparse]
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
To connect to them, I use 10-conductor IDC connectors.· These are easy to attach to the end of a 10-wire ribbon.· I get the ribbon cable from old surplus·PC disk cables.
Not sure what you mean by DIP Cat-5 connectors, but I use Cat-five through-hole connectors that solder to a PCB.
I'm using all this stuff in a current project, and have ordered (and received) them all within the last couple weeks.·
Male 2-row straight-up, 72 positions (cut or break off as many as you need).· This will make 7 10-pin headers.
Mouser # 649-68691-172HLF $1.83 each
Male 2-row right-angle, 72 positions (cut or break off as many as you need).· This will make 7 10-pin headers.
Mouser # 649-79257-272HLF $2.17 each
Female IDC connector to squeeze onto the end of the ribbon cable and connect to either of the above, 10-pin.
Mouser # 164-9006-E $0.39 each.· I install these using a small vise, but it's possible even with pliers.
Cat-5 connector, PCB mount.
Mouser # 571-55583411 $1.70 each
Mouser has no minimum order and they usually ship (from the Fort Worth area) the same day.· Their order line is 800-346-6873.· I have found them pleasant and reliable.· You can look at pictures of these items at www.mouser.com if you enter the above part numbers in the search box.
· -- Carl, nn5i@arrl.net
