Needing help find a company(s) to order small quanties for wire harness — Parallax Forums
eagletalontimeagletalontim Posts: 1,399
edited 2009-02-02 14:45 in General Discussion
I am looking to purchase some kind of 10 wire male / female connectors that can be soldered to a PCB. The other connector needs to have the contacts to connect wires. With an extremely limited budget, I need to be able to order small quantities. I am also looking for inexpensive DIP Cat-5 female connectors. Cheaper is better [noparse]:)[/noparse]
    edited 2009-01-31 02:56
    Try DigiKey. They have a custom assembly department and can make cable assemblies from any parts they carry in stock. I use them on a regular basis.
  • eagletalontimeagletalontim Posts: 1,399
    edited 2009-01-31 02:58
    ok, thanks [noparse]:)[/noparse]
  • LeonLeon Posts: 7,620
    edited 2009-01-31 16:38
    I use Molex KK connectors with a low-cost hand tool for making up my own cable assemblies. It's the best way if you only need a small quantity like that.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • Carl HayesCarl Hayes Posts: 841
    I use two-row male pin connectors soldered to the PCB, basically the same thing used on computer motherboards for connecting ribbon cables, but without the little plastic walls around them.· These come in right-angle male and in straight-up male.
    To connect to them, I use 10-conductor IDC connectors.· These are easy to attach to the end of a 10-wire ribbon.· I get the ribbon cable from old surplus·PC disk cables.
    Not sure what you mean by DIP Cat-5 connectors, but I use Cat-five through-hole connectors that solder to a PCB.
    I'm using all this stuff in a current project, and have ordered (and received) them all within the last couple weeks.·
    Male 2-row straight-up, 72 positions (cut or break off as many as you need).· This will make 7 10-pin headers.
    Mouser # 649-68691-172HLF $1.83 each
    Male 2-row right-angle, 72 positions (cut or break off as many as you need).· This will make 7 10-pin headers.
    Mouser # 649-79257-272HLF $2.17 each
    Female IDC connector to squeeze onto the end of the ribbon cable and connect to either of the above, 10-pin.
    Mouser # 164-9006-E $0.39 each.· I install these using a small vise, but it's possible even with pliers.
    Cat-5 connector, PCB mount.
    Mouser # 571-55583411 $1.70 each
    Mouser has no minimum order and they usually ship (from the Fort Worth area) the same day.· Their order line is 800-346-6873.· I have found them pleasant and reliable.· You can look at pictures of these items at www.mouser.com if you enter the above part numbers in the search box.
    · -- Carl, nn5i@arrl.net
