No Stamps Found Error
I am an educator who is just learning about Sumobot.
I keep getting the error "No Stamps Found" and I
cannot seem to find the correct COM port to download
BS2 files.
Haaalllllppp!!!!
BS2 files.
Haaalllllppp!!!!
The "No Stamps Found" error message could be caused by a low battery. If that does not solve the problem please supply a few more details that will allow us to troubleshoot your problem.
Craig
I have just assembled the robots, and tried connecting
them to my computer using a serial to USB cable.
I am supposed to align my servo motors using the Basic Stamp Editor v. 2.4.2
Nothing seems to work.
- Stephen
http://forums.parallax.com/forums/default.aspx?f=15&m=184304
It is a USB to RS232 cable.
I installed drivers that came with the cable, and I also
downloaded the drivers from Parallax web site.
I don't Know about your cable but it sounds like a likely candidate for issues.
I assume you have the port listed in your program from the Directive menu.
Have you tried to ID the ports?
I can connect to any USB port, but I cannot seem to download files
from Parallax.
I found a Usb to Serial cable that works with stamps from Sewell Part #SW-1301 About $13.00 plus shipping.
Parallax probably has one that works also. I know that doesn't help you out right now but that is where I would start.
I'll be in touch later on.
what was going on.
The default USB to serial adapter driver in Windows doesn't seem to handle DTR properly. You really do need to install the "full service" driver from the adapter's manufacturer to get DTR to work and don't be surprised if many adapters don't work for you. A lot of them just implement the transmit and receive data lines and the RTS and CTS control lines and leave off DTR and DSR.
Take a look at the USB to serial converter from Parallax part#28030. It will cure all of Your Problems.
cost is around $15 BUCKS
I use this all the time, And it works great.
__________$WMc%________
The Truth is out there············································ BoogerWoods, FL. USA
