No Stamps Found Error — Parallax Forums
BarbzBarbz Posts: 8
edited 2009-02-01 07:22 in BASIC Stamp
I am an educator who is just learning about Sumobot.
I keep getting the error "No Stamps Found" and I
cannot seem to find the correct COM port to download
BS2 files.
Haaalllllppp!!!!
  • BarbzBarbz Posts: 8
    edited 2009-02-01 04:15
    My email is mbarbari@mts.net
  • Mike2545Mike2545 Posts: 433
    edited 2009-02-01 04:19
    What kind of cable/connection are you using?
  • Craig EidCraig Eid Posts: 106
    edited 2009-02-01 04:20
    Barbz,
    The "No Stamps Found" error message could be caused by a low battery. If that does not solve the problem please supply a few more details that will allow us to troubleshoot your problem.
    Craig
    edited 2009-02-01 04:33
    I have a fresh set of batteries installed into each sumobot.
    I have just assembled the robots, and tried connecting
    them to my computer using a serial to USB cable.
    I am supposed to align my servo motors using the Basic Stamp Editor v. 2.4.2
    Nothing seems to work.
    edited 2009-02-01 04:34
    Which cable (manufacturer) and have you loaded the drivers before connecting the cable?
    - Stephen
    edited 2009-02-01 04:37
    Is the USB to serial from Radio Shack?
  • MSDTechMSDTech Posts: 342
    edited 2009-02-01 04:38
    This sounds like the USB-Serial problem that many have experienced. Try using the instructions at:
    http://forums.parallax.com/forums/default.aspx?f=15&m=184304
    edited 2009-02-01 04:44
    I purchased the cable at a store called Computer Avenue.
    It is a USB to RS232 cable.
    I installed drivers that came with the cable, and I also
    downloaded the drivers from Parallax web site.
    edited 2009-02-01 04:51
    Unfortunetly, the communications protocol for the basic stams is not supported by many USB-RS232 adaptors and I think you may have found one. You need to get an adaptor based on the FTDI chip to support the programming protocol.
    edited 2009-02-01 04:54
    I have heard that some USB to Serial cables don't work with the Stamps.
    I don't Know about your cable but it sounds like a likely candidate for issues.
    I assume you have the port listed in your program from the Directive menu.
    Have you tried to ID the ports?
    edited 2009-02-01 04:58
    I have tried to ID the Ports, and it does seem to recognize them.
    I can connect to any USB port, but I cannot seem to download files
    from Parallax.
    edited 2009-02-01 05:04
    Does you CPU have a serial port or do you have to use a USB port.
    I found a Usb to Serial cable that works with stamps from Sewell Part #SW-1301 About $13.00 plus shipping.
    Parallax probably has one that works also. I know that doesn't help you out right now but that is where I would start.
    edited 2009-02-01 05:06
    Thanks for now everyone.
    I'll be in touch later on.
    edited 2009-02-01 05:08
    I have USB ports, and I have tried all of them to see
    what was going on.
    edited 2009-02-01 05:25
    As others have mentioned, not all USB to serial adapters work with the Stamps. The Stamps have to have the DTR (data terminal ready) signal to be able to be identified and programmed and some inexpensive (cheap!) USB to serial adapters don't include this in the signal lines that they implement properly. Parallax uses a chip from FTDI to make their adapters and FTDI sells several adapters themselves and all of them seem to work. I've also had success with Keyspan's High Speed Serial Adapter.
    The default USB to serial adapter driver in Windows doesn't seem to handle DTR properly. You really do need to install the "full service" driver from the adapter's manufacturer to get DTR to work and don't be surprised if many adapters don't work for you. A lot of them just implement the transmit and receive data lines and the RTS and CTS control lines and leave off DTR and DSR.
  • $WMc%$WMc% Posts: 1,884
    Barbz
    Take a look at the USB to serial converter from Parallax part#28030. It will cure all of Your Problems.
    cost is around $15 BUCKS
    I use this all the time, And it works great.
    __________$WMc%________
    The Truth is out there············································ BoogerWoods, FL. USA
