Holding 0805 resistors in place — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2009-01-30 18:38 in General Discussion
Which is the best way to hold down the SMT resistor to solder it by hand?
Should I
1. Use some glue?
2. Hold it down with a tweezer?
3. Hold it down using a finger nail?
4. Use sticky flux? ( where to buy this? )
www.fd.com.my
www.mercedes.com.my
    edited 2009-01-30 03:59
    I use the following method using a the stick from wooden cotton swabs: www.circuitmedic.com/guides/7-3-1.shtml
    Glue will also work fine, but I would recommend using a gel type superglue to prevent the glue from running onto the pads.
    Andrew Williams
    WBA Consulting
    IT / Web / PCB / Audio
    edited 2009-01-30 04:06
    I use solder paste and an oven. But sometimes I have to replace a part and solder a new one in by hand. Here's how I do it:
    1. If you're replacing a part, suck the old solder from both pads using solder wick.
    2. Apply a small bead of solder to one pad using the iron.
    3. Grap the resistor/cap with tweezers and press it against the pads.
    4. Heat up the pad with the solder bead until the solder melts, and press the part into it.
    5. Let the part cool.
    6. Solder the other end of the part to the remaining pad. Work fast, though, so you don't melt the solder on the first pad.
    7. Use solder wick to clean up any bulging solder globs, leaving a nice fillet.
    I've never had a part tombstone using this technique.
  • uxoriousuxorious Posts: 126
    At work we use the method that WBA_Consulting and PhiPi mention. Tweezers or "orange sticks" are used to hold the parts. "Orange sticks" are ESD plastic sticks that are flat like a screwdriver on one end and a point on the other. We use this method for all surface mount passives down to 0201 size parts.
    We use the CircuitMedic website all the time for reference and training. Good site.
    ~~ dRu ~~
