I am having a really bad problem with the propeller tool
I have submitted this problem before but I cannot get things working again.
I can only get programs to load intermittently. I have deleted everything.
Re downloaded new software, checked drivers, deleted everything and reinstalled
everything. Still the same problem. Even added xp service pack three and no changes.
HELP!!!
HELP!!!
Do you have a com port open when you attempt to download? For example, the serial terminal when enabled blocks the com port.
con
_clkmode = xtal1 + pll16x
_clkfreq = 5_000_000
I suddenly remembered this and experimented. Nothing works at pll16x only pll8x and below.
Apps that do not use this con block work. When added they stop working at 16x but work at
lower speeds.
I have just spent an hour experimenting with adding and deleting the con block to apps and changing
the speeds and this appears to be the culprit.
Thanks for your help.
Martin
Are you using the Spin Stamp? That module has a 10MHz crystal, and you should specify it thus:
pll16x will not work because that results in a clock frequency of 160MHz, which is beyond the Propeller's specs.
· Emulators (Micros eg Altair, and Terminals eg VT100) - index
My cruising website is: ·www.bluemagic.biz
Martin
