I am having a really bad problem with the propeller tool — Parallax Forums
pilot00pilot00 Posts: 30
edited 2009-03-07 17:25 in Propeller 1
I have submitted this problem before but I cannot get things working again.
I can only get programs to load intermittently. I have deleted everything.
Re downloaded new software, checked drivers, deleted everything and reinstalled
everything. Still the same problem. Even added xp service pack three and no changes.
HELP!!!
  • SRLMSRLM Posts: 5,045
    edited 2009-01-25 23:46
    Is your propeller reliably powered?
    Do you have a com port open when you attempt to download? For example, the serial terminal when enabled blocks the com port.
  • pilot00pilot00 Posts: 30
    edited 2009-01-25 23:55
    I finally figured it out. Josh at techsupport told me of a problem with
    con
    _clkmode = xtal1 + pll16x
    _clkfreq = 5_000_000
    I suddenly remembered this and experimented. Nothing works at pll16x only pll8x and below.
    Apps that do not use this con block work. When added they stop working at 16x but work at
    lower speeds.
    I have just spent an hour experimenting with adding and deleting the con block to apps and changing
    the speeds and this appears to be the culprit.
    Thanks for your help.
    Martin
    edited 2009-01-26 00:26
    Martin,
    Are you using the Spin Stamp? That module has a 10MHz crystal, and you should specify it thus:
    con
      _clkmode = xtal1 + pll8x
      _clkfreq = 10_000_000
    pll16x will not work because that results in a clock frequency of 160MHz, which is beyond the Propeller's specs.
    edited 2009-01-26 00:32
    This doesn't make sense to me as I use this all the time. Is your crystal 5.00MHz? Maybe the PLL is not working (chip failure)?
    · Emulators (Micros eg Altair, and Terminals eg VT100) - index
    · Search the Propeller forums (via Google)
    My cruising website is: ·www.bluemagic.biz
    edited 2009-01-26 06:44
    If the PLL wasn't working, _pll8x would not work either, since it's divided from the 16x clock. I suspect he's using a 10MHz crystal. I make that mistake all the time, since I'm working with both crystal frequencies on different boards. I'm almost embarassed to say how much time it costs me every time I do it!
    Problem was solved due to a malfunction on the propeller chip. Parallax replaced the chip. thanks for the support.
    Martin
