2x16 Parallel LCD work with the BASIC Stamp Activity Kit
will the 2x16 Parallel LCD work with the BASIC Stamp Activity Kit·? if not what lcd works with the homework board?
Post Edited By Moderator (Joshua Donelson (Parallax)) : 10/23/2009 4:13:04 AM GMT
Also what other stuff do i need to hook it up with my bs2 homework board
A backlight is worth an extra 5 bucks in my opinion.
You'll need nothing additional to connect it to your homework board... although the Servo Extension cable would be nice if you plan on having it off your solderless breadboard.
also is their any example circits or codes i can use?
