Difference between the SX-Blitz and the SX-Key
Dan Taylor
Hi All:
I am soon to be getting a SX Programmer and have to choose a plug. What is the difference between the SX-Blitz and the SX-Key? There is like a $20.00 difference in cost. Why? Thanks for any answers.
btw Thanks for posting!
Dan Taylor
Post Edited (Dan Taylor) : 1/15/2009 8:16:08 PM GMT
Dan Taylor
The SX-Blitz will only allow you to program the SX chips (which is fine for most projects)
For the extra $20 the SX-Key will allow you to program the SX chips (like the SX-Blitz) and it will also allow you to do in circuit debugging of your program (with a few restrictions). In order to perform debugging you need to unplug any external clock sources (resonator, TTL oscillator) so the SX-Key can generate the clock or you won't be able to enter debug mode.
If you only want to program the chips and don't need the debugger then the SX-Blitz if just fine.
Robert
Dan Taylor
If you are new to the SX, get the SX-Key. The debugging feature is a "must have" for getting to know the SX.
Bean.
·The next time you need a hero don't look up in the sky...Look in the mirror.
I missed your last post.
The debugging on the SX chip works alot differently than the BS2.
You cannot output text like the BS2 DEBUG command.
You can set breakpoints, watch variables, single step code, etc.
Trust me, get the SX-Key.
Bean.
I use both the SX-Blitz and SX-Key and most of the time just use them for programming the chips.
Robert
Dan Taylor
