Using Resonators with Propeller
Hi,
Can I replace my 5Mhz crystal directly with a 4Mhz resonator and just ground the middle pin?
Thanks.
www.fd.com.my
www.mercedes.com.my
Thanks.
www.fd.com.my
www.mercedes.com.my
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I don't know why they are cheaper.
www.fd.com.my
www.mercedes.com.my
Prop Tools under Development or Completed (Index)
http://forums.parallax.com/showthread.php?p=753439
My cruising website http://www.bluemagic.biz
Cluso99 is correct. One place you may notice the consequences is with video output — especially composite color, which requires a very accurate timebase.
I just need to run faster than 20Mhz.
In order to reduce the effects of the built-in capacitors in a 3 pin resonator, should i leave the middle pin unconnected?
The Propeller datasheet seems to lack info on which types on resonators will work.
www.fd.com.my
www.mercedes.com.my
You should be able to simply leave the ground connection disconnected. A two-terminal resonator would be cheaper, and more convenient, though.
Leon
