Using Resonators with Propeller
william chan
Can I replace my 5Mhz crystal directly with a 4Mhz resonator and just ground the middle pin?
Thanks.
www.fd.com.my
www.mercedes.com.my
Thanks.
www.fd.com.my
www.mercedes.com.my
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I don't know why they are cheaper.
www.fd.com.my
www.mercedes.com.my
Prop Tools under Development or Completed (Index)
http://forums.parallax.com/showthread.php?p=753439
My cruising website http://www.bluemagic.biz
Cluso99 is correct. One place you may notice the consequences is with video output — especially composite color, which requires a very accurate timebase.
I just need to run faster than 20Mhz.
In order to reduce the effects of the built-in capacitors in a 3 pin resonator, should i leave the middle pin unconnected?
The Propeller datasheet seems to lack info on which types on resonators will work.
www.fd.com.my
www.mercedes.com.my
--------X--------- | | C C | | --------- |You should be able to simply leave the ground connection disconnected. A two-terminal resonator would be cheaper, and more convenient, though.
Leon
