Using Resonators with Propeller — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2009-01-12 06:02 in Propeller 1
Hi,
Can I replace my 5Mhz crystal directly with a 4Mhz resonator and just ground the middle pin?
Thanks.
www.fd.com.my
www.mercedes.com.my
  • LeonLeon Posts: 7,620
    edited 2009-01-11 11:47
    Those three terminal ceramic resonators have built-in feedback capacitors. It would be better to use one without the capacitors (two terminals). Why don't you want to use a crystal?
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • william chanwilliam chan Posts: 1,326
    edited 2009-01-11 12:31
    Resonators are cheaper....
    I don't know why they are cheaper.
    www.fd.com.my
    www.mercedes.com.my
    edited 2009-01-11 12:49
    They are cheaper but are not as accurate
    Prop Tools under Development or Completed (Index)
    http://forums.parallax.com/showthread.php?p=753439
    My cruising website http://www.bluemagic.biz
    edited 2009-01-11 17:49
    William,
    Cluso99 is correct. One place you may notice the consequences is with video output — especially composite color, which requires a very accurate timebase.
    edited 2009-01-12 03:50
    In my application, accuracy is not crucial.
    I just need to run faster than 20Mhz.
    In order to reduce the effects of the built-in capacitors in a 3 pin resonator, should i leave the middle pin unconnected?
    The Propeller datasheet seems to lack info on which types on resonators will work.
    www.fd.com.my
    www.mercedes.com.my
    As the internal circuit of the resonator looks like this:
        --------X---------
          C         C
    You should be able to simply leave the ground connection disconnected. A two-terminal resonator would be cheaper, and more convenient, though.
    Leon
