Vocal Tract #sine error — Parallax Forums
mctriviamctrivia Posts: 3,772
edited 2009-01-11 19:49 in Propeller 1
every time I try to compile the VocalTract object I get an error on line 326 saying
"Expected a DAT symbol."
the line says "call #sine"
not sure why it does not work for me. anyone know how to fix?
    edited 2009-01-11 09:06
    Download the latest Propeller Tool. A change was made in the compiler a while back to allow a label like sine_ret to be a 'res'. Or, you can change that 'call #sine' to 'jmpret sine_ret,#sine'. That might be easiest, for now.
    Chip Gracey
  • mparkmpark Posts: 1,336
    edited 2009-01-11 17:09
    What was the reason for the compiler change?
    edited 2009-01-11 17:26
    Just wanted to be able to use 'res' declarations as ???_ret points. Nothing else.
    mpark said...
    Chip Gracey
    edited 2009-01-11 19:39
    This is a great object you have writen but using it is not to easy. Do you know of any table or and notes I could use to learn how to make it reproduce different words? I am currently trying to get it to audibly say the time of day.
    This thread may help you a little. It's a phonetic speech synthesizer I wrote that uses Chip's vocal tract object. It's pretty rough and not very well documented, but it may give you some ideas.
