VSS and VDD pins
Im having fun messing around designing some boards for the first time and my question is...
Is it neccisary / a good idea·to supply vdd and vss to all of the vss and vdd pins on the prop or can i leave some unconnected and should you always place a .1uf cap between each? is it also pretty much rule of thumb to do it on any ic? such as mcp3208?
thanks
Jesse
thanks
Jesse
You do need to connect at least one 0.1uF cap between Vdd and Vss of each chip, particularly for complex chips like a processor or ADC. PCB board traces have some inductance and that will prevent power from getting to the chip from the source on the PCB for a short period of time. The 0.1uF caps provide a power reservoir for a short time. Sometimes you can get away with using one 0.1uF cap for each pair of ICs when they're physically adjacent on the board and the power traces are short.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
BTW, a groundplane should not be treated as some magic monolithic trace. This is particularly true when it gets broken up a little by those few short signal traces that need to be routed there. You have to pay attention to the ground current flows. I call it the "feng shui" of PCB design. I will even add deliberate breaks to the groundplane from time to time, in order to coerce the return flow along a certain route, for example, between the power connector at the edge of the board and the voltage regulator.
As to the clock traces, I've only ever used 8-mil traces there and haven't encountered any problems. The main thing is to keep them short. Too wide a trace might result in too much capacitance with the ground plane.
I use ordinary signal tracks for crystals, to avoid introducing additional capacitance, as Phil has pointed out.
Leon
Just to keep the convo flowing a little... here's my first attempt at a board.. It was made for a little project i was making to control· a camera for astronomy. I aslo added some other features such as the ability to trigger·shutter based on other external sensors. Lcd goes on top of the prop.
I etched it myself as test all seemed to work and i sent it off to· pcb house(batchpcb) just for fun and to learn how it comes back[noparse]:)[/noparse] As you can see those red traces were more of a test to see how the top layer comes back etc. I didnt want to mess with a top layer when etching myself but wanted to see how the vias etc worked.
So now·I know my board is missing the .1uf caps [noparse]:)[/noparse] and besides more use of the second layer what else can be improved upon?
Post Edited (s2jesse) : 1/11/2009 12:57:32 AM GMT
