Help with FTDI and Propeller
OK, Ive spent the past 2 weeks trying to get this to work. I ordered a Propeller chip from Digikey about two weeks ago. Originally my plan was to build to serial programmer circuit included in the data sheet. When that didn't work I orderd one of these, a USB to Serial 3.3V TTL Adapter. I cant get it to work either. No matter what I do the Propeller Tool says no propeller chip found. When I ground the RESn pin temporally, I can see no evidence of a reset (although I don't have a scope). But if I pull the power out of it and plug it back in I get "00" over the serial port.
Here's a pic of my layout.
Also, before I made the power supply, I was powering the chip with an arduino's 3.3V output.
Any help would be greatly appreciated.
You could also order a Prop plug.
Thanks for the help.
I took a look into the datasheet of the
TTL-232R USB to TTL Serial Converter Cable
on page 5 is a table describing
The RS232-pins that are connected to the TTL-side are
1 GND GND Black Device groud supply pin.
2 CTS# Input Brown Clear to Send Control input / Handshake signal.
3 VCC Output Red +5V Output
4 TXD Output Orange Transmit Asynchronous Data output.
5 RXD Input Yellow Receive Asynchronous Data input.
6 RTS# Output Green Request To Send Control Output / Handshake signal.
So as you mentioned you have to setup the proptool to send the reset signal on RTS
and if you take a close look into the circuit of the propeller-datasheet page 5 2.3.2. Alternative Serial Port Connection
there is a capacitor of 0.1 µF between serial-plug and resetpin of the propeller
one thing
you could test if there starts some bitbanging on IO-Pins 28,29 right after powerup (propeller trys to communicate with the EEPROM connected to pins 28,29)
second thing write a small testprogram save the binaryfile of it
load binaryfile into an 32kB EEPROM using any kind of programmer and connect it to the propeller
best regards
Stefan
Post Edited (StefanL38) : 1/7/2009 10:37:07 PM GMT
Thanks!
http://forums.parallax.com/showthread.php?p=774630
> "Lastly, is there any way I can tell if the chip is working without the serial working?"
If you have a o'scope you can look at the PA28, PA29 to see if the Propeller tries to access the EEPROM. Evt. you need a Pullup on Pin PA29 for that (2..10k).
If you have no Scope, perhaps a LED flashes briefly when attached at PIN PA29 to +3.3V over a ~200 Ohm resistor. But the pulse may bee to short to see.
Andy
