Help with FTDI and Propeller — Parallax Forums
tazdartazdar Posts: 4
edited 2009-01-10 05:21 in Propeller 1
OK, Ive spent the past 2 weeks trying to get this to work. I ordered a Propeller chip from Digikey about two weeks ago. Originally my plan was to build to serial programmer circuit included in the data sheet. When that didn't work I orderd one of these, a USB to Serial 3.3V TTL Adapter. I cant get it to work either. No matter what I do the Propeller Tool says no propeller chip found. When I ground the RESn pin temporally, I can see no evidence of a reset (although I don't have a scope). But if I pull the power out of it and plug it back in I get "00" over the serial port.
Here's a pic of my layout.
Also, before I made the power supply, I was powering the chip with an arduino's 3.3V output.
Any help would be greatly appreciated.
  • grasshoppergrasshopper Posts: 438
    edited 2009-01-07 21:52
    I would think that in order to get it to work correctly you would need to place a transistor that could be used by the USB chip (using the DTR) to toggle the reset pin on the propeller. Otherwise I imagine that it would work, but I have not seen the USB data sheet.
    You could also order a Prop plug.
  • tazdartazdar Posts: 4
    edited 2009-01-07 22:07
    Thanks for the quick response, here's the pin out for the usb to serial. I'm not sure on the details of RTS/CTS or DTR but I have the RTS pin on the usb running to the RESn pin directly on the propeller. I set the reset signal to RTS in the prop tool as well. Lastly, is there any way I can tell if the chip is working without the serial working?
    Thanks for the help.
    edited 2009-01-07 22:19
    Hello tazdar,
    I took a look into the datasheet of the
    TTL-232R USB to TTL Serial Converter Cable
    on page 5 is a table describing
    The RS232-pins that are connected to the TTL-side are
    1 GND GND Black Device groud supply pin.
    2 CTS# Input Brown Clear to Send Control input / Handshake signal.
    3 VCC Output Red +5V Output
    4 TXD Output Orange Transmit Asynchronous Data output.
    5 RXD Input Yellow Receive Asynchronous Data input.
    6 RTS# Output Green Request To Send Control Output / Handshake signal.
    So as you mentioned you have to setup the proptool to send the reset signal on RTS
    and if you take a close look into the circuit of the propeller-datasheet page 5 2.3.2. Alternative Serial Port Connection
    there is a capacitor of 0.1 µF between serial-plug and resetpin of the propeller
    one thing
    you could test if there starts some bitbanging on IO-Pins 28,29 right after powerup (propeller trys to communicate with the EEPROM connected to pins 28,29)
    second thing write a small testprogram save the binaryfile of it
    load binaryfile into an 32kB EEPROM using any kind of programmer and connect it to the propeller
    best regards
    Stefan
    Post Edited (StefanL38) : 1/7/2009 10:37:07 PM GMT
    edited 2009-01-07 23:06
    Tried the capacitor, no joy [noparse]:([/noparse] Thoughts?[noparse]:)[/noparse]
    Thanks!
  • AribaAriba Posts: 2,694
    edited 2009-01-07 23:38
    Try to invert the RTS signal with MPROG (an FT232 configuration program from FTDI), and add a 10..100nF C between the RTS and Reset input. Or use the transistor circuit here:
    http://forums.parallax.com/showthread.php?p=774630
    > "Lastly, is there any way I can tell if the chip is working without the serial working?"
    If you have a o'scope you can look at the PA28, PA29 to see if the Propeller tries to access the EEPROM. Evt. you need a Pullup on Pin PA29 for that (2..10k).
    If you have no Scope, perhaps a LED flashes briefly when attached at PIN PA29 to +3.3V over a ~200 Ohm resistor. But the pulse may bee to short to see.
    Andy
    Hey thanks for the responses guy's, inverting the RTS signal with MPROG worked great.
