Some one build my board.
                    Hi everyone. I used ExpressPCB to draw a Prop Proto Board I did not finish the Vga Mouse Keyboard wires because of money. I put the pins on the board need to have the Parallax adapter then print this and make it match then hook up the last wires. It is a great board I just dont have the money to print it. I hope some one likes it and builds it for all of us to buy. Let me know what you think.
Phildapill has made you a nice offer, why wouldn't finish off the board and connect the VGA and PS/2 then? Allow for a pull-up on the RXD input for when the Prop Plug is not connected.
*Peter*
On second thought, now that I see this is a double sided board, I can't do this at home. I can only do single sided PCBs...
This would be a bit difficult to "print" - you have this board set up as a 4-layer (two layers for power/ground). This makes it improbable for most DIY'ers.
-Tim
Thanks so much for the fast replies!! And if you want to look at my 80c85 vintage videos. www.youtube.com/user/abfig78
Post Edited (KD5VMF) : 1/4/2009 4:21:36 AM GMT
Here's a board I just finished using EAGLE. I'm actually sending it off today to get fabricated. It's a two SINGLE layer board, and all routing was done by hand. It's amazing how compact you can make a board with 100's of hours of work! I'm doing something similiar to you. I've made my board, going to get it fab'ed, and then sell them, but only at cost. I just want to see how the whole process work. You can check the evolution and some other pointers in this thread:
http://forums.parallax.com/showthread.php?p=773086
Post Edited (Philldapill) : 1/3/2009 10:33:40 PM GMT
I like it!!! I have not use smt circuits yet. I would have to print boards then. I set my Prop proto up hoping to make a computer. That is why I put the real time clock on board. You know. I have to thank Parallax for inspiring me to learn as much as I have this year.
