Getting Started
I am pretty new to designing my own circuits to use with my propeller and I am constantly hitting the problem of not having some common parts around to try my ideas out I would like to get my work shop going and·would like to know: What are some of the most common electronic components that you use and or are generally good to have around?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Resistors:
1.1k
560k
270k
10k
100ohm
220ohm
Caps:
10uf electrolytic
M/F single row pin headers
M/F double row pin headers
Connectors:
PS2 jacks
RCA M/F connectors
LEDs (various)
Plenty of breadboard wire
(Saves time when soldering up projects or breadboard testing)
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
www.digikey.com/
mouser.com/
My experience - at the end of a project you're always missing one part. Radio Shack carries a good supply of resistors and capacitors. For the other stuff like headers, connectors, LED's and IC's I use Sparkfun. They also carry some inexpensive breakout boards that have come in handy.
www.sparkfun.com/
As for parts, OBC and Leon are right. You can never have enough 0.1uF capacitors on hand, and not having the right resistors is just a pain when you have to rig up a series/parallel combination just to meet the right value.
