Getting Started — Parallax Forums
Getting Started
TrezitorulTrezitorul Posts: 68
edited 2009-01-04 17:20 in General Discussion
I am pretty new to designing my own circuits to use with my propeller and I am constantly hitting the problem of not having some common parts around to try my ideas out I would like to get my work shop going and·would like to know: What are some of the most common electronic components that you use and or are generally good to have around?
  • LeonLeon Posts: 7,620
    edited 2009-01-03 18:12
    A complete set (10 of each will do) of 1% metal film 1/4W resistors, and plenty of 100 nF monolithic ceramic capacitors are the most important items.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    edited 2009-01-03 18:14
    Not sure what you have but here is my list of top items to keep around...
    Resistors:
    1.1k
    560k
    270k
    10k
    100ohm
    220ohm
    Caps:
    10uf electrolytic
    M/F single row pin headers
    M/F double row pin headers
    Connectors:
    PS2 jacks
    RCA M/F connectors
    LEDs (various)
    Plenty of breadboard wire
    (Saves time when soldering up projects or breadboard testing)
    OBC
    New to the Propeller?
    Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
    Got an SD card connected? - PropDOS
  • TrezitorulTrezitorul Posts: 68
    edited 2009-01-04 04:06
    Thanks for all of the suggestions do you recommend any particular place to get all of these items.
  • ForrestForrest Posts: 1,341
    edited 2009-01-04 05:35
    You should be able to get just about any component you need from:
    www.digikey.com/
    mouser.com/
    My experience - at the end of a project you're always missing one part. Radio Shack carries a good supply of resistors and capacitors. For the other stuff like headers, connectors, LED's and IC's I use Sparkfun. They also carry some inexpensive breakout boards that have come in handy.
    www.sparkfun.com/
  • PhilldapillPhilldapill Posts: 1,283
    I use Futurlec.com for most of my "common" parts. Prices are very reasonable, and the shipping is only $4 for orders up to $29, and $6 for orders up to $49. It takes about a week to get here, however. If you're breadboarding your circuit, I'm ordering some simple PCB's that plug into your breadboard for easy access to the propeller. The board has all the parts needed to run the propeller, already on it. I'm ordering these boards in bulk so If you're interested, PM me to be added to the list. Sorry if this seems spam-ish, but I think for a new propeller user, this sort of thing would eliminate alot of your hassle of wiring the circuit up.
    As for parts, OBC and Leon are right. You can never have enough 0.1uF capacitors on hand, and not having the right resistors is just a pain when you have to rig up a series/parallel combination just to meet the right value.
