MCP3208 Analog Chips - Page 2 — Parallax Forums
2
  • danthonydanthony Posts: 45
    edited 2008-12-30 19:46
    will do....
    edited 2008-12-31 22:41
    Jim-Just making sure I am referencing raw data and not an average in MCP3208_Fast
    example: adc.in(1,0)
    It is producing data that coincides with the sensor but just making sure....
    edited 2008-12-31 23:09
    sorry, chipnumber is in rear, I meant (0,1) instead of (1,0)·
    basically in the .in··· right?
  • mynet43mynet43 Posts: 644
    edited 2008-12-31 23:49
    Here's the calling sequence:
    val := adc.in(chan, chipnum) ' get single adc value
    Jim
    edited 2009-01-01 02:44
    Jim
    7 segment leds and knight rider scroll....
    pic attached
    582 x 928 - 157K
    edited 2009-01-02 19:16
    Jim,
    Latest data.....
    Don
    1280 x 800 - 177K
    1280 x 800 - 172K
    1280 x 800 - 180K
    1280 x 800 - 182K
    1280 x 800 - 181K
    edited 2009-01-02 21:21
    Hi Don,
    Looks like you've been working. Here's what I see from the pics.
    1. You didn't say what the scope is hooked up to. Is it the voltage output from the 1st IR sensor?
    2. Comparing the first two pics, it looks like the sensor has something in its range the whole time of the scan.
    This is because the average voltage is higher in the second pic. Is it seeing you in the beam? OK if it is.
    3. Your trigger seems to be set around 0.7 V, I would set it to around 1.5 V to eliminate the noise.
    4. Along with setting the trigger higher, I would also change it from Continuous to Single shot mode.
    It the trigger is right, then it should sit there until it sees the barbell and then spike.
    5. If you can, increase the sample rate so you see a shorter period with greater detail.
    6. You might also want to change from Auto to a Fixed voltage scale, say 0 to 5 V.
    That way, all the pics will have the same reference scale.
    Let me know if you have more questions.
    Jim
    edited 2009-01-02 22:08
    Hey Jim,
    1.) It is hooked to the output of sensor 1 voltage
    2.) They have a steady .7v with nothing in front of them, it is in the GP2Y specs as well. I am not sure why. What I was trying to showing with the first 2 pics was that with only 1 sensor, it has a clean output. With multiple sensors shining the same way, it gets messier.
    3.) I will make the trigger suggestions.
    4.) I think the prop has the sensors pinned as being the weak link.
    I'll be back....
    edited 2009-01-03 01:25
    Don,
    The reason for moving the trigger to 1.5 V and setting it to single shot mode was to make it see nothing until the signal was greater than 1.5 V.
    This way you'll see the signal on the scope only when the barbell is lifted into its beam.
    Anything else will be too far away (voltage too low) to trigger the scope.
    Jim
    edited 2009-01-03 17:00
    Don,
    I attached the voltage response curve for the IR sensor you're using.
    It looks like the barbell should be between 1 and 2 meters from the sensor.
    And everything else more than 2 meters from it.
    Then if you ignore all adc readings less than 1.5 V, it should have no problem seeing the barbell.
    You can choose a different voltage, such as 2.0 V if the barbell is about 1 meter from the sensor.
    I think you should have no problem with the sensor you're using.
    Jim
    800 x 591 - 60K
    edited 2009-01-03 20:14
    Jim,
    That was the intent from conception before 1 soaked up 800 of them. It doesn't work that way as we have developed more than 2 generations of this thing. Each time we add sensors it adds some sort of distortion at sensor idle feedback. If you note one of the pics had a nice smooth line to follow. The distortion grows in amplitude and seems unpredictable.
    Now that we finally have a high speed machine (propeller chip) I am able to put these sensors to the test. It hasn't gotten much better with detection. The small object whizzing by doesn't help either. But that is the challenge.
    The best detection from 6 years of playing with this is through-beam technology. I haven't seen a diffuse sensor that scans this far and this precise for the money as the Sharp Gp2Y. I still need to bring some things to life here for final analysis (i.e. your 74hc's) but just from these scope tests I am bummed out. Basically it misses the bb during high speed movements.
    Don
    edited 2009-01-03 23:24
    Hi Dan,
    You should be able to display the voltage seen by the adc chip and compare this with the chart.
    This should be more reliable than the scope setup you have.
    I've used a very similar IR sensor with this adc. It gives reasonably good range results.
    You should be able to see it in the little pic to the left, it's the scanning eye of the robot.
    Just code a 100 ms loop to update the voltage display at the same place on the screen.
    It sounds like something isn't set up quite right. Once you see the voltage, you should
    be able to tell what's going on.
    Let me know if you need help with the display code.
    Jim
    edited 2009-01-05 21:14
    Jim-
    Did you have multiple eyes pointing in the same direction on your robot?
    Don
    edited 2009-01-06 01:38
    Don,
    No, in this case it's just the one eye on the post in back. It scans back and forth to see where it's going.
    Jim
    edited 2009-01-06 12:39
    That is what I was getting at. If there is more than 1 it seems to throw garbage ito the other sensors at idle. I am not sure why, but with just 1 sensor it is perfect. More than 1 make some sort of distortion.
    I made the 100ms loop to pc terminal. What do you want me to look for. It just seems the update is slower now and doesn't update as fast.
    edited 2009-01-06 14:22
    I sent you a PM to display the adc readings under different target conditions.
    Let's use this thread for attachments only, unless someone else is interested[noparse]:)[/noparse]
    I wish they'd fix the PM forum to allow attachments... Anyone listening?
    Jim
    edited 2009-01-06 17:53
    will this work (look in lower left of screen)?
    1280 x 800 - 149K
    edited 2009-01-10 20:43
    Jim, Is this what you wanted?
    Don
    1280 x 800 - 108K
    edited 2009-01-11 01:04
    Don,
    This is a good start.
    I need to know what your test conditions are:
    1. How often are you sampling each port of the 3-MCP3208's?
    Maybe you could post the code used to generate the display.
    2. What are the target conditions for the 24 IR sensors.
    I.e. Is the barbell in front of sensors 0 thru 3, are you standing farther away in front of all of the sensors?
    What I need to know is what each sensor SHOULD be seeing, to correlate the adc voltages.
    Remember, each target should be at least a meter from the sensor.
    3. The middle sensors (channels 8 thru 15) seem to have reasonable values.
    The first and third MCP3208's (channels 0 thru 7 and 16 thru 23) seem to have strange values.
    The very low and very high values don't look right. Check the wiring of these strange ones.
    How about posting the code you use to generate the values, along with a photo of the test setup.
    Make sure you use the code directive before and after the code, to make it easier to read.
    Hang in there, you're getting close.
    Jim
    edited 2009-01-11 01:20
    i didn't have it in the rack there, just making sure the screen will do...
    edited 2009-01-11 01:34
    '' DonTest_multi -- 12/26/08
    '' Used to test MCP3208_fast_multi with up to 3 MCP3208's attached to Prop
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
    ' VGA and Keyboard info for vga.start
      BasePin  = 16                 ' base pin for video output (0, 8, 16, 24) - 16 on proto board
      kbd_dpin = 26                 ' keyboard dpin number - pin 26 on proto board
      kbd_cpin = 27                 ' keyboard cpin number - pin 27 on proto board
      kbd_lock = %0_001_000         ' keyboard locks: disable scroll lock key, NumLock, CapsLock, ScrollLock all off
      kbd_auto = %01_01000          ' keyboard auto repeat: 0.5 sec delay, 15 chars/sec repeat (?)
      kbdflag  = 0                  ' set this to 1 if a keyboard is connected/needed
    ' MCP3208 adc stuff
      dpin1     = 10                 ' ADC data pin on Propeller
      cpin1     = 11                 ' ADC clock pin on Propeller
      spin1     = 12                 ' ADC Chip Select pin on Propeller
      dpin2     = 13                 ' ADC data pin on Propeller
      cpin2     = 14                 ' ADC clock pin on Propeller
      spin2     = 15                 ' ADC Chip Select pin on Propeller
      dpin3     = 25                 ' ADC data pin on Propeller
      cpin3     = 26                 ' ADC clock pin on Propeller
      spin3     = 27                 ' ADC Chip Select pin on Propeller
      'chipnum   = 1                  ' chip number to test
    ' Don's conversion factor to get us from count
      us =  80
    VAR
      long CS
      long DIO
      long CLK
      long    txa, txb ,txc, txd ,txe, y0, x0
      long scantime, admcp1[noparse][[/noparse]7], admcp2[noparse][[/noparse]7], admcp3[noparse][[/noparse]7]
    DAT
    ' Misc Values
      AOK         byte  "All COGs Started, ready to rock!", 0
      OOPS        byte  "Oops, cog start failed...",0
    ' Values for Test_adc routine
      ADCdisp     byte  "ADC", 0
      VALdisp     byte  "val:     ", 0
      AVGdisp     byte  "avg of 10 samples:     ", 0
      CLKcycl     byte  "clk cycles:       ", 0
    OBJ
    '' Include VGA/Keyboard, MCP3208 ADC and Floating Point Objects
      adc :    "MCP3208_fast_multi"
      debug :  "FullDuplexSerialPlus"
      vp:      "Conduit"
      SReg :   "HC595mod2"
      'vga:     "VGA_1024"
    PUB Init | char, b, chipnumb, chip2cnt, chip3cnt, r
      debug.start(31,30,0,115200)
      debug.tx(Debug#CRSRX)                                 'indent
      debug.tx(3)
      '' start ADC chip MCP3208
      if adc.start(dpin1, cpin1, spin1, dpin2, cpin2, spin2, dpin3, cpin3, spin3)
         waitcnt(clkfreq * 1 + cnt)                         'wait 1 second for cog to start
      else
            debug.Str(String(" OOPS No COG " ,debug#CR))
      debug.Str(String(" AOK COG Start Up " ,debug#CR))
      SReg.InitSer595                                       ' to initialize driver
      SReg.writeSer595(%000000000000100000000000)           ' set up data to send to chip
      waitcnt(clkfreq/100 + cnt)
      debug.Str(String("MCP 3208 Tests" ,debug#CR))
      debug.tx(Debug#CRSRX)                          'position the cursor on X (indent)
      debug.tx(10)
      debug.tx(Debug#CRSRY)                          'position the cursor on Y (up and down)
      debug.tx(3)
      debug.Str(String("Sensor #    Raw Value     Sensor Voltage      Set Point     Number of Hits ", debug#CR))
      b := 0
      repeat
        repeat while chipnumb <4
         b :=0
          repeat while b <8
              chipnumb := 1
              r := adc.in(b,Chipnumb)    '  87us
              debug.tx(14 )
              debug.tx(5 + b)
              debug.dec(b++)
              debug.Str(string("          "))
              debug.dec (r)
              debug.dec ((r*5000)/4096)
              debug.Str(string(" mv    ",debug#CR))
          repeat while   b > 7 AND b < 16
              chipnumb := 2
              r := adc.in((b-8),chipnumb)    '  87us
              debug.tx(14 )
              debug.tx(5 + b)
              debug.dec(b++)
              If b < 10
              else
              debug.dec (r)
          repeat while   b > 15 AND b < 24
              chipnumb := 3
              r := adc.in((b - 15),chipnumb)    '  87us
              debug.tx(14 )
              debug.tx(5 + b)
              debug.dec(b++)
              debug.dec (r)
        waitcnt(clkfreq/5 + cnt)      ' wait about 100 ms
      ' transfer the mcp data to global variables
      Test_adc
      repeat while TRUE                     ' loop forever to keep COGs running
    PUB Test_adc
      repeat
          txe := cnt                         ' init time for 24 reads
          admcp1[noparse][[/noparse]0] :=  adc.in(0,1)
          admcp1[noparse][[/noparse]1] :=  adc.in(1,1)
          admcp1[noparse][[/noparse]2] :=  adc.in(2,1)
          admcp1[noparse][[/noparse]3] :=  adc.in(3,1)
          admcp1[noparse][[/noparse]4] :=  adc.in(4,1)
          admcp1[noparse][[/noparse]5] :=  adc.in(5,1)
          admcp1[noparse][[/noparse]6] :=  adc.in(6,1)
          admcp1[noparse][[/noparse]7] :=  adc.in(7,1)
          admcp2[noparse][[/noparse]0] :=  adc.in(0,2)
          admcp2[noparse][[/noparse]1] :=  adc.in(1,2)
          admcp2[noparse][[/noparse]2] :=  adc.in(2,2)
          admcp2[noparse][[/noparse]3] :=  adc.in(3,2)
          admcp2[noparse][[/noparse]4] :=  adc.in(4,2)
          admcp2[noparse][[/noparse]5] :=  adc.in(5,2)
          admcp2[noparse][[/noparse]6] :=  adc.in(6,2)
          admcp2[noparse][[/noparse]7] :=  adc.in(7,2)
          admcp3[noparse][[/noparse]0] :=  adc.in(0,3)
          admcp3[noparse][[/noparse]1] :=  adc.in(1,3)
          admcp3[noparse][[/noparse]2] :=  adc.in(2,3)
          admcp3[noparse][[/noparse]3] :=  adc.in(3,3)
          admcp3[noparse][[/noparse]4] :=  adc.in(4,3)
          admcp3[noparse][[/noparse]5] :=  adc.in(5,3)
          admcp3[noparse][[/noparse]6] :=  adc.in(6,3)
          admcp3[noparse][[/noparse]7] :=  adc.in(7,3)
          vp.share(@scantime, @admcp3[noparse][[/noparse]7])
        scantime := ((cnt - txe) /us)
    edited 2009-01-11 03:41
    Hi Don,
    I discovered a couple of thing with the code:
    You have to be very careful with the indenting within repeat loops.
    In this code:
      b := 0
      repeat
         b :=0
          repeat while b <8
    You don't need the first two lines, since the second repeat loop repeats forever.
    Also, the way you're doing the test, you should replace the lines
         b :=0
    with just:
        repeat
          b :=0
    Notice a couple of things here. The b := 0 needs to be indented two spaces, not one.
    Also, the value of chipnumb is not defined before this repeat and is not needed here.
    Finally, the line:
    should be:
              r := adc.in((b - 16),chipnumb)    '  87us
    Since the first value of b is 16 for this loop.
    Even with these little changes, I don't think we've accounted for the strange numbers seen
    in the first and third MCP3208 chips. The voltage returned should always be between 500 and 3000 mv,
    according to the range response curve I posted above.
    Check the wires and let me know when you get a test case setup with values.
    Have fun.
    Jim
    edited 2009-01-11 16:32
    '' * "HC595.spin"  74HC595 SPIN Object                                          *
    '' * coded by Jim -- 12/31/08 -- Happy New Year!                                *
    '' * Version 1.0        *
    '' Calling sequence
    '' OBJ
    ''   SReg : "HC595"
    '' code segment
    ''   SReg.InitSer595              ' to initialize driver
    '' more code
    ''   DataByte := toSend           ' set up data to send to chip
    ''   SReg.WriteSer595(DataByte)   ' send data to chip
    '' more code
    CON
      _PinHigh        = 1
      _PinLow         = 0
      CLK           = 16             ' pin number of CLK  pin on chip (AKA SCK)
      SER           = 17             ' pin number of SER  pin on chip
      CLR           = 18             ' pin number of SCLR pin on chip
      RCK           = 19            ' pin number of RCK  pin on chip
      GPN           = 20             ' pin number of G    pin on chip
    VAR
      long  bitout, databyte
    PUB InitSer595                  ' initialize 74HC595 for startup
      ' set the control lines as outputs
      dira[noparse][[/noparse]CLK] ~~
      dira[noparse][[/noparse]SER] ~~
      dira[noparse][[/noparse]CLR] ~~
      dira[noparse][[/noparse]RCK] ~~
      dira[noparse][[/noparse]GPN] ~~
      outa[noparse][[/noparse]CLK] := _PinLow          ' init main  clock line to low
      outa[noparse][[/noparse]RCK] := _PinLow          ' init latch clock line to low
      outa[noparse][[/noparse]GPN] := _PinHigh         ' set outputs to 3-state
      outa[noparse][[/noparse]CLR] := _PinLow          ' set to clear register on chip
      outa[noparse][[/noparse]GPN] := _PinLow          ' turn on the chip and clear pins
      outa[noparse][[/noparse]CLR] := _PinHigh         ' return CLR pin to high after clear
    PUB WriteSer595(Data)           ' Data is long with 8 bits of data in bits 7 - 0
      ' Write 8 bits of data.         Data byte is output MSB first.
      databyte := Data              ' transfer to working storage
      repeat 24                      ' shift out 8 bits
        bitout := databyte & %1000_0000_0000_0000_0000_0000  ' take hi bit from byte -> bitout bit 7
        bitout >>= 23                ' shift to bit zero for output
        databyte <<= 1              ' shift data left 1 bit for next loop
        outa[noparse][[/noparse]SER] := bitout         ' shift out high bit to serial pin (0 or 1)
        outa[noparse][[/noparse]CLK] := _PinHigh       ' toggle the clock pin to shift bit out
        outa[noparse][[/noparse]CLK] := _PinLow        ' high then low to cycle the clock
      outa[noparse][[/noparse]RCK] := _PinHigh         ' toggle the RCK pin to latch the output
      outa[noparse][[/noparse]RCK] := _PinLow          ' high then low to cycle the clock
    edited 2009-01-16 02:31
    Hey Jim,
    Here are some more pics
    Don
    2576 x 1932 - 626K
    2576 x 1932 - 427K
    1932 x 2576 - 801K
    edited 2009-01-16 02:43
    Jim, one more
    2576 x 1932 - 668K
    edited 2009-01-16 15:17
    I've posted the MCP3208 multi-chip support driver to the Object Exchange, "MCP3208_fast_multi".
    This driver supports up to 24 ADC channels using up to three MCP3208 ADC 8-port 12-bit chips.
    danthony has been testing it using 24 IR range sensors, and it seems to be working fine.
    The calling sequence is different than the original driver, due to the multi-chip support.
    Here are the main entry points:
    PUB start(dpin1, cpin1, spin1, dpin2, cpin2, spin2, dpin3, cpin3, spin3) : okay
    '' Start driver - starts a cog
    '' returns false if no cog available
    '' may be called again to change settings
    ''   dpin  = pin connected to both DIN and DOUT on MCP3208
    ''   cpin  = pin connected to CLK on MCP3208
    ''   spin  = pin connected to CS  on MCP3208
    ''   dpin1 = dpin for 1st MCP3208, etc.
    PUB in(channel, chip)
    '' Read the current sample from an ADC channel (0..7)
    '' Chip number 1, 2 or 3
    PUB average(channel, chip, n)
    '' Average n samples from an ADC channel (0..7), n <= 16
    Let me know if you have any questions.
    Jim
  • TubularTubular Posts: 4,774
    edited 2009-01-16 20:42
    Don,
    Did you locate the source of the intereference? Could it be the illumination from the other 23 IR emitters, bouncing off the round barbell, could be the source of the noise? This could be checked by fixing the barbell in position, monitoring the single closest channel while covering up a range of the other 23 sensors?
    I'm using the MCP3304 in an 4 channel application (works well) and am about to test the same sharp sensor for a silo level monitoring application. No plans yet for multiple sensors, but knowing how these things tend to evolve... so thanks for blazing the trail.
    And many thanks Jim for the driver
    tubular.
    edited 2009-01-16 22:20
    Hi Tubular
    I second that thanks to Jim for the driver. The interference happens without anything in front of the sensors at all. The sensors are packed so close tight it could be related. However it works pretty good.
    What are you looking at in the silo?
    Don
    edited 2009-01-17 08:32
    ... said...
    Feed grain for cows, mostly.·· And the occasional field mouse.
    tubular
    edited 2009-01-17 18:26
    Jim here is the outline you asked for.
    Don
