I/O pins and Crystals
Just curious about routing traces on a PCB that come very close the the crystal. I'm designing a PCB for the propeller, and it would be great if I could move some traces closer to the crystal. My traces will be on the opposite side of the board as the crystal, but is there any sort of EM interference between the crystal and traces that could be a problem?
possible to the pins to insure accurate function.
EE's correct me if I'm wrong here..
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
I attached a pic with the xtal pretty close to the Red VGA line.
Jim
That's a nice little crystal you've got. What is it?
The most practical crystal I've found in in an HC49 package which is about as long as the QFP propeller chip.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Here's a pic of the XTAL, with the specs and P/N.
The body of the xtal is a little less than 3/8" long.
I've used it on several boards and it's great!
Jim
Thanks for the info, it now makes much more sense.
The crystal is still as large as the ones that I use, it just gets to stand vertically instead of horizontally.
For the record I use DigiKey Part # 535-9087 which is a ABLS-5.000MHz-B2-T type crystal.
Leon
Sorry to carry on two threads here.
Thanks for the info on the xtal you use. I like it much better than the usual through-hole type. I may order some.
You said they're about the same size, however, the Digikey part is about 45% bigger than the Newark part (0.5"/0.346").
The reason I like the Newark part is its very small footprint when you're trying to fit a lot on a little board.
The footprint is a circle 3 mm across, about 0.1", which isn't much space.
I may use yours for some apps because it's so close to the board, which I like.
Jim
