I/O pins and Crystals — Parallax Forums
PhilldapillPhilldapill Posts: 1,283
edited 2009-01-02 14:31 in Propeller 1
Just curious about routing traces on a PCB that come very close the the crystal. I'm designing a PCB for the propeller, and it would be great if I could move some traces closer to the crystal. My traces will be on the opposite side of the board as the crystal, but is there any sort of EM interference between the crystal and traces that could be a problem?
    edited 2009-01-02 03:30
    I'm not an EE, but as I understand it the Crystal needs be as close as
    possible to the pins to insure accurate function.
    EE's correct me if I'm wrong here..
    OBC
    New to the Propeller?
    Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
    Got an SD card connected? - PropDOS
  • mynet43mynet43 Posts: 644
    edited 2009-01-02 03:36
    I've built quite a few boards and never had a problem with the xtal location.
    I attached a pic with the xtal pretty close to the Red VGA line.
    Jim
    1026 x 528 - 393K
  • PhilldapillPhilldapill Posts: 1,283
    edited 2009-01-02 03:40
    Oh, the crystal itself is very close. I think total trace lengths are less than 1/2", probably closer to 1/4". I was just concerned about any sort of "cross-talk" scenario where a trace has alot of AC through it, e.g. an output toggling very quickly. Now that I've thought about it more, I doubt there would be any problem...
  • mirrormirror Posts: 322
    edited 2009-01-02 04:24
    Jim,
    That's a nice little crystal you've got. What is it?
    The most practical crystal I've found in in an HC49 package which is about as long as the QFP propeller chip.
  • LeonLeon Posts: 7,620
    You might be thinking about high-speed clock signals, which can couple energy into adjacent tracks.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    edited 2009-01-02 04:31
    @mirror
    Here's a pic of the XTAL, with the specs and P/N.
    The body of the xtal is a little less than 3/8" long.
    I've used it on several boards and it's great!
    Jim
    1681 x 996 - 293K
    xtal.jpg 292.9K
    edited 2009-01-02 07:00
    Jim,
    Thanks for the info, it now makes much more sense.
    The crystal is still as large as the ones that I use, it just gets to stand vertically instead of horizontally.
    For the record I use DigiKey Part # 535-9087 which is a ABLS-5.000MHz-B2-T type crystal.
    edited 2009-01-02 08:17
    Leon, yes, that is the sort of thing I was worried about. There's always the possibility that a highspeed device might be attached, which uses a high freq. clock signal. One particular device I have in mind is a TLV2543. It's an ADC that uses a 4MHz signal from an I/O pin. Let's say that this clock pin is the one that is riiiight next to the leads of the crystal(0.025"). Could this mess with the operation of the crystal? If so, I have some major re-routing to do...... ugh.
    edited 2009-01-02 09:25
    You shouldn't get any problems at that frequency. Running the track at right angles to the crystal tracks will minimise coupling, anyway. Or use another output.
    Leon
    mirror,
    Sorry to carry on two threads here.
    Thanks for the info on the xtal you use. I like it much better than the usual through-hole type. I may order some.
    You said they're about the same size, however, the Digikey part is about 45% bigger than the Newark part (0.5"/0.346").
    The reason I like the Newark part is its very small footprint when you're trying to fit a lot on a little board.
    The footprint is a circle 3 mm across, about 0.1", which isn't much space.
    I may use yours for some apps because it's so close to the board, which I like.
    Jim
