HB-25 Motor Controller
Just a quick question about this motor controller. I saw on the catalog that you can controll 2 motors if they are moving in the same direction, do they have to be the same speed also, for example if I needed my bot to turn by slowing down the wheel speed of the right side?
Thanks!
Thanks!
What you are describing is turning by using skid steering which will require two HB25s.
Each HB25 will control two motors in parallel on each side of the robot/rover.
Appropriate PWM signals from a MCU (BS2, etc) can be used to skid steer the robot/rover in any direction.
Hope this helps.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
