HB-25 Motor Controller — Parallax Forums
totcohandtotcohand Posts: 28
edited 2009-01-02 05:41 in Robotics
Just a quick question about this motor controller. I saw on the catalog that you can controll 2 motors if they are moving in the same direction, do they have to be the same speed also, for example if I needed my bot to turn by slowing down the wheel speed of the right side?
Thanks!
  • Tom CTom C Posts: 461
    edited 2009-01-02 04:49
    totcohand,
    What you are describing is turning by using skid steering which will require two HB25s.
    Each HB25 will control two motors in parallel on each side of the robot/rover.
    Appropriate PWM signals from a MCU (BS2, etc) can be used to skid steer the robot/rover in any direction.
    Hope this helps.
    TCIII
    If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
  • totcohandtotcohand Posts: 28
    Thanks Tom that clears it up!
