BS2px pin will not go high
Hello all,
I have a BS2px with pin 14 connected to a button through a 330 ohm resistor. The input is pulled low by a 10K resistor. However, when the button is pushed, the basic stamp's pin will only reach about 3v. This circuit only reaches 5v if the basic stamp is removed.
Thanks for any help.
I'm with philpi on this one. Can You attach some code Your using? and a jpeg of the circuit?
This will make leaps and bounds on Your Project.
_____$WMc%______________Happy New Year
The Truth is out there
