UPDATED: PropBoard for Review(and sale!)
I've been designing a compact, "plugable" propeller board for a few weeks now, and would like some feedback and review of it. I've fried way too many propellers because of careless mistakes with jumper wires on a breadboard. I've gotten tired of fiddling with all these wires and loose parts, so I've had enough of it. I can make my own PCB prototypes, and have done so for a while now. However, I can only get a certain precision and scale with my methods, so I'd like to get a few of my boards fabricated by a professional PCB maker.
I'm sure a few of you others have also fried a chip or two, and to make this cost effective, I'm going to get about 20 of these boards made. I'll probably keep 3 or 4 of these boards for my own purposes, and I'd like to sell the rest. I've attached a picture of the board. It includes a single PS/2 port for a keyboard or mouse. I've always wondered why the protoboard has 2 of these. I've never had to use a mouse and keyboard at the same time, but whatever... Anyway, it also has a 2.5mm DC power jack for a walwart. The crystal will be removable so that you can replace it with whatever you want. This is specifically a DIP chip board. This is to make it a little easier to just replace the chip by dropping a new one in, rather than trying to solder the SMD chip, like on the protoboard. The EEPROM is also DIP, even though it seems rare to blow this one. One note about the picture - I've added a couple of jumpers to the clock and data lines of the PS/2. This is so that if you are not using it, you can take the jumpers off, and there will be no problems if you are using pins 26 and 27 for something else.
One final note, this board is meant to be·"plugged in" to a breadboard OR, you can put female headers in place of the male headers and make it a board that you plug only the wires you want, into it.
If anyone is interested in a board, let me know. And please, be mean in your critiques! This is one of my first REAL boards that I will be making and I want to get it totally right!·[noparse]:)[/noparse]
EDIT: By the way, the dimensions are 2" x 3.4".
Post Edited (Philldapill) : 12/31/2008 11:16:07 PM GMT
Nice work!
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Oh, forgot to mention I'd like one of those boards also.
So, now, here are the features:
- I/O pins 0 through 27, plus regulated 3.3V and Ground are all out front able to plug into a small 30 row breadboard(or any other larger one) perfectly
- 1 PS/2 port on pins 26 and 27, with the ability to "disconnect" it via 2 jumper pins, allowing zero interference on these pins when they are used for another purpose
- 1 Composite TV output on pins 20-22, again with the ability to "disconnect" via 3 jumper pins
- 5V and Vin are available via female pin headers on front of board
- Propeller and eeprom are in DIP packages for easy removal and replacement
- Input power is supplied via a 2.5mm DC power jack(inside barrel plug is negative, outside is positive)
- Costs less than a propeller itself, but saves chips by no loose prototyping wires!
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
This looks like a great board and I like the improvements you've made.
Whit+
Post Edited (Whit) : 12/31/2008 3:04:37 PM GMT
John Abshier
I agree!
Everything on the bench is 2.1, CENTER Positive. 2.5 center negative would be a nuisance...
I'm trying to keep this board simple enough for the most common items. An LCD is a common item, but with the TV plug I'm adding, an LCD seems a little redundant, not to mention allllll those pins it would need.
John,
Do you know what diameter holes #4 are in inches? Doesn't have to be exact, since I can always make the wholes slightly larger to make sure the screws fit. Adding these holes will make the board a good half inch bigger on each side... Plus, I'm adding the TV composite plug on the bottom right corner, so the screws may get in the way if you want to use them AND the TV.
Whit,
THANK YOU for a keen eye. I was only taking into account the actual female headers on the prop plug when I was positioning the PS/2. I forgot that the PCB of the prop plug is slightly wider. I've corrected this now.
Brian - the man of propeller PCBs,
I was under the assumption that the 2.5mm plug was the common type... As for the polarity, if the opposite polarity is much more common, then that is an easy fix. Please let me know which polarity is more common - the one I have on the board, or the opposite.
Everyone,
To keep the cost down for these boards, I'm shooting to get at least 20 boards made. I'm keeping 3 for myself, so that means I'll need to get orders for 17 more. I'm selling these at cost, for the most part, with the more specific components included. These components are: the two regulators, the header pins in front, the header pins for the prop plug, the reset switch, and the power plug(just tell me what kind you need). As for the video plug, PS/2 and other non-essential resistors, just let me know if you want those too for a buck extra(at cost).
Thanks guys for all the feedback!
Major diameter on #4 screws is .112", clearance for tight fit is .116" and for loose fit is .128"
By the way, the board is looking great. When will you be posting the revised layout with the changes?
Ed
(2) mounting holes works fine for me - looks like there's some room on the side with the PS2 connector.
John Abshier
Brian
- Added Qty. 4, 0.125"(#4) holes on the corners. The spacing is 3.4" x 1.75"
- Changed the 5V and Vin access
- Added a crude TV Adapter which is a serpate board with resistors/RCA plug on it. This can be plugged in and should be pretty structurally stable.
- Fixed the spacing between the PS/2 and Prop Plug pins
- Changed the DC Jack to a 2.1mm, center positive, which seems to be the most common type.
- Added the ability to "disconnect" the PS/2 by removing two jumpers. This eliminates any problems with the PS/2 port being attached, but pins 26 and 27 used for other things.
Looking at futurlec's pricing for 15 boards with solder mask, each PCB should cost about $5.75, unpopulated. With all the components, minus propeller and eeprom, it should run about $10. Fully loaded with a Propeller, eeprom and all components, $25. Still less than a protoboard!
Post Edited (Philldapill) : 1/1/2009 12:13:09 AM GMT
Jim Fouch
FOUCH SOFTWARE
OBC
One last comment, you've got to get your name, ©, date and rev. # on there somewhere!
Philldapill Prop Board ©
2009 Rev. A
Whit+
Post Edited (Whit) : 1/1/2009 1:02:44 AM GMT
I just got a design done that I put a USB connector to far away from the edge of the board. I had to dremel away part of the board to get the USB cable to plug in. My lesson learned, was to order the parts ahead of time and have them in your hand while designing. I had 4 of those boards made as prototypes. One of them sit on my desk now, unpopulated. I set my coffee cup on it.
Brian
To all of those that are interested that have not already expressed so, please Private Message me with your details such as Name, Address, Number of boards you'd like, whether you want just the board and regulator, the board with basic components(sockets, regulators, power jack, pins, resistors, but no PS/2 or RCA), or if you want everything on it except for the propeller and eeprom. I feel like I'm taking orders for pizzas...
To those of you that have expressed interest in a board or two, I'll PM you tomorrow and get your info. Right now, it's time to party like it's 1999.
Happy New Year!
Ed
Chris Savage
Parallax Engineering
Thanks for all the replies, guys.
