Bitwise Encode Problem — Parallax Forums
T ChapT Chap Posts: 4,248
edited 2008-12-30 18:31 in Propeller 1
Can someone please help me understand why the following produces an 'expected end of line' error:
word  KPBPinInput
byte adminpw[noparse][[/noparse] 3]
adminpw[noparse][[/noparse] 3] := >|KPBPinInput
The KPBPinInput contains any possible input from a keypad read with I2C into the word var. I want to convert the keypad bitfield into its corresponding number, and according to the manual:
PinNum := >|Pin
The above example sets PinNum equal to the number of the highest bit set in Pin, plus 1.
Thanks for any suggestions
Post Edited (TChapman) : 12/30/2008 3:28:30 AM GMT
  • mynet43mynet43 Posts: 644
    edited 2008-12-30 03:34
    It looks like you allocated three bytes for storage.
    You can use index 0, 1 and 2 but not 3.
    Maybe there's something else...
  • T ChapT Chap Posts: 4,248
    edited 2008-12-30 03:47
    Thanks, I have experimented with variations, allocating doesn't fix the error.
    edited 2008-12-30 03:50
    mynet3 is right, but that's a semantic error. The error being reported is a syntax error. Based on what little you've shown, you should not get such an error, but there's a lot of context missing. So, without seeing the rest of your code, it's impossible to say where the problem is.
    edited 2008-12-30 04:01
    Oops sorry guys, this appears to be a BST issue, compiles on Proptool.
    Thanks for the help.
    Post Edited (TChapman) : 12/30/2008 4:09:17 AM GMT
    edited 2008-12-30 04:15
    Here's a test case I wrote:
    VAR
      long UserNumber, testlong
    PUB Init
    ' init vga display
      testlong := %1000_0000_0000_0000_0000_0000_0000_0000
      repeat
        testy
      repeat
    PUB testy
      UserNumber := >|testlong
      vga.cursloc(40,30)
      vga.dec(UserNumber)
    It works perfectly and displays the number 32 over and over...
    Jim
  • BradCBradC Posts: 2,601
    edited 2008-12-30 14:18
    TChapman said...
    Can you show me how to reproduce it please? I've not been able to here.
    Cardinal Fang! Fetch the comfy chair.
    edited 2008-12-30 18:02
    Hey Brad
    I recall that there was a recent save that gave a warning about unicode, although I don't know why.
    When I opened the file in Proptool, it said invalid characters found and the offenders were highlighted in white, simply a blank space between "UserNumber" and ":=", I backspaced over the space, then hit the space bar again, then it compiled fine. I saved it, reloaded in bst and it is fine. Some how a space became invalid, but I have no idea how. Easy fix though, need to pay heed to the unicode flags in the future.
    Fab, thanks [noparse]:)[/noparse]
    I now know to double check the Unicode stuff around the editor and see if I can get something non-standard to happen.
