Bitwise Encode Problem
Can someone please help me understand why the following produces an 'expected end of line' error:
The KPBPinInput contains any possible input from a keypad read with I2C into the word var. I want to convert the keypad bitfield into its corresponding number, and according to the manual:
PinNum := >|Pin
The above example sets PinNum equal to the number of the highest bit set in Pin, plus 1.
Thanks for any suggestions
Post Edited (TChapman) : 12/30/2008 3:28:30 AM GMT
word KPBPinInput byte adminpw[noparse][[/noparse] 3] adminpw[noparse][[/noparse] 3] := >|KPBPinInput
PinNum := >|Pin
You can use index 0, 1 and 2 but not 3.
Maybe there's something else...
Thanks for the help.
Post Edited (TChapman) : 12/30/2008 4:09:17 AM GMT
VAR long UserNumber, testlong PUB Init ' init vga display testlong := %1000_0000_0000_0000_0000_0000_0000_0000 repeat testy repeat PUB testy UserNumber := >|testlong vga.cursloc(40,30) vga.dec(UserNumber)It works perfectly and displays the number 32 over and over...
Jim
Can you show me how to reproduce it please? I've not been able to here.
Cardinal Fang! Fetch the comfy chair.
I recall that there was a recent save that gave a warning about unicode, although I don't know why.
When I opened the file in Proptool, it said invalid characters found and the offenders were highlighted in white, simply a blank space between "UserNumber" and ":=", I backspaced over the space, then hit the space bar again, then it compiled fine. I saved it, reloaded in bst and it is fine. Some how a space became invalid, but I have no idea how. Easy fix though, need to pay heed to the unicode flags in the future.
I now know to double check the Unicode stuff around the editor and see if I can get something non-standard to happen.
