Trouble programming the SX. — Parallax Forums
P!-RoP!-Ro Posts: 1,189
edited 2008-12-30 01:38 in General Discussion
I just got started programming the SX, but when I tried I got·an error·message. I tried doing as it said and searching for the COM port options, but·it wasn't available. What is wrong?
PG
    edited 2008-12-28 12:17
    Can you give us a few more details on your setup?
    - Are you using the new USB SX-Key, older Serial SX-Key, or the SX-Blitz programmer?
    - If you are using the Serial SX-Key is it connected directly to a serial port or are you going through a USB to Serial adapter?
    - If you are using the Serial SX-Key is the target device powered? The Serial SX-Key gets its power from the target being programmed.
    - What is the board you are trying to program? Is it a Parallax development board or something home grown?
    - What OS are you running on the system? Do you have any Virus scanners that may be blocking access to Serial ports?
    - Although unlikely is the SX-Key plugged in backwards on the 4-pin header for programming?
    - What is the clock source for your target system? Is it going to use the internal RC clock, a resonator, or a crystal? If you have a crystal as a clock source the crystal must be unplugged or you can't program the chip. If it is in the circuit it may also damage the SX-Key
    - If there is a resonator in the circuit you should be able to program the chip but you can't debug. In order to debug all the clock sources other than the SX-Key must be disconnected.
    Let us know and we should be able to help.
    Best Regards,
    Robert
    edited 2008-12-28 15:13
    "Port COM does not exist on this machine."
    If you go to Run in the Toolbar and select Configure from the drop-down menu you'll see the "radio buttons" for available serial ports.·
    The USB-serial has to be plugged in before you run the SX IDE, it looks for what's out there when it boots but doesn't check again afterward.
  • P!-RoP!-Ro Posts: 1,189
    Yup, the crystal was in the circuit. Once I took it out I could find the option to use COM 7, but now all the programmer does is turn on a blue light. Guess I'll have to replace it then.
    PG
