Has any one used a transformer that can sense from .1 up to 30 Amps like this
Here is the link to it
I bought 4 of these to try out
http://www.goldmine-elec-products.com/prodinfo.asp?number=G16866
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 12/25/2008 3:43:21 PM GMT
··Thanks for any·
·that you may have and all of your time finding them·
Sam
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
- Stephen
though it stats it can sense up too 30 amps
It·can sense up to 30 amps because the primary side of the transformer is one turn of # 10 solid wire
Franklin
I going to use·one in a project called ·Electronic Fuse Controller· controlled ·by a Basic Stamp
Leon
This the first time I have seen one this small that will handle 30 amps
I want to Thank all three of you for your replies
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 12/26/2008 12:49:41 PM GMT
Leon
I suppose you will rectify and smooth the output
What type of caps would you recommend for smoothing out the output
··Thanks for any·
Sam
Leon
You have to use a ADC0831 8-bit A/D converter DIP to be able to measure voltage with a Basic Stamp
I will try this with a 470 uF to start with and see what happens
Thanks for your input to this Project and·
··Thanks for any·
Sam
