Has any one used a transformer that can sense from .1 up to 30 Amps like this — Parallax Forums
sam_sam_samsam_sam_sam Posts: 2,286
edited 2008-12-27 15:25 in General Discussion
Here is the link to it
I bought 4 of these to try out
http://www.goldmine-elec-products.com/prodinfo.asp?number=G16866
··Thanks for any·idea.gif·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 12/25/2008 3:43:21 PM GMT
  • LeonLeon Posts: 7,620
    edited 2008-12-25 16:26
    It looks like a standard current transformer.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    edited 2008-12-26 02:46
    Sam, what do you plan to do with them?
    - Stephen
  • marzec309marzec309 Posts: 146
    edited 2008-12-26 05:37
    though it stats it can sense up too 30 amps. It will required a large wattage resistor in parallel with it to take some of the burden off of it.
    edited 2008-12-26 12:44
    Marc
    It·can sense up to 30 amps because the primary side of the transformer is one turn of # 10 solid wire
    Franklin
    I going to use·one in a project called ·Electronic Fuse Controller· controlled ·by a Basic Stamp
    Leon
    This the first time I have seen one this small that will handle 30 amps
    I want to Thank all three of you for your replies
    Sam
    Post Edited (sam_sam_sam) : 12/26/2008 12:49:41 PM GMT
    edited 2008-12-26 15:09
    Sounds interesting. I suppose you will rectify and smooth the output, then use the BS to measure the voltage?
    Leon
    edited 2008-12-27 12:52
    Leon
    What type of caps would you recommend for smoothing out the output
    Sam
    edited 2008-12-27 15:09
    The current will be quite low, so something like 470 uF might be OK. A little ripple shouldn't cause any problems. I don't know much about the BS, but I suppose it has some way of measuring voltage.
    Leon
    Leon
    You have to use a ADC0831 8-bit A/D converter DIP to be able to measure voltage with a Basic Stamp
    I will try this with a 470 uF to start with and see what happens
    Thanks for your input to this Project and· idea.gifs
    Sam
