USB to 232 / SX-KEY
I am trying to get my SX stuff to work from my laptop that only has USB no 232 Serial ports. I have a USB to 232 hooked up to my Serial SX-Key.. My FTDI assigns Port 18 when I plug in the USB Cable to my computer.. but when I go to program the SX-28 it says that it can't find an SX-KEY on the port I choose. Is there a problem with this setup?
Thanks in Advance,
Eric
Thanks in Advance,
Eric
What port are you choosing? Port 18? Are you running the latest version of the IDE?
PeterM
Robert
I've upgraded the FTDI drivers to the most current.
Is there a way to test the USB to 232 Device? Maybe it's bad.
Eric
It works well with some programs, I can program directly a Basic Stamp with it, but I have problems with other hardware. For instance I couldn't program a USB2Bluetooth device even if I was able to connect to it.
The same happens with my SXkey. The key is detected, the chip memory is erased, but it stops somewhere when writing to the device. It stops anywhere during the progress bar, but I cannot get to the end.
Maybe we could open a thread listing working/not working devices?
Massimo
