analog voltage reading with BS1? — Parallax Forums
PauloPaulo Posts: 21
edited 2008-12-26 13:58 in BASIC Stamp
The POT command allows for a sort of analog input by charging an RC net and timing discharge of capacitor.
Although Application Notes bring a clever usage of an external A/D converter, I was wondering what would happen if I block the POT instruction charging phase with a diode while using another pin to control a switching device to the voltage to be measured. See attached schematic.jpg
It would be read this way:
PULSOUT switch, 100
POT input, scale, voltage
I'm am not at my shop, so I can't try it, just wonder if it would work. Next week I'll give it a try, but would appreciate any comments on the idea.
Post Edited (Paulo) : 12/19/2008 1:00:22 AM GMT
  • PauloPaulo Posts: 21
    edited 2008-12-24 02:14
    Sure it required some adjustments, but the general idea works just fine.
    The hardware modification was only to leave the usual resistor in series between the diode and capacitor (diode forward resistance was not enough, I guess).
    In the reading software I found necessary to "seal" input pin to avoid having it sink the variable voltage I want to charge the capacitor, and providing a small delay to allow for capacitor charging.
    The new circuit is in the attached figure (relay driver omitted, but sure it IS a relay). Tomorrow I'll try a FET for switching but I'm not sure it will work. A bipolar transistor will NOT work.
    This is how I read the analog voltage:
    Main:
    LOW relay ' opens relay leaving capacitor charged with whatever voltage it got
    POT input, scale,volts ' the diode blocks charging phase so it reads the external variable voltage thru fixed resistor
    HIGH input ' "seals" the input by placing its voltage above the higher voltage to be read
    HIGH relay ' closes relay for next reading
    DEBUG volts ' display voltage
    PAUSE 50 ' short delay to allow for capacitor charging
    GOTO Main ' repeat forever
    When I finish all testing I'll inform component values, voltage ranges, byte to voltage conversion equation, etc.
    782 x 436 - 11K
    edited 2008-12-24 02:24
    Thanks for posting a follow-up. Interesting, I'll look forward to hearing more about your app.
    Well, the FET did about the same as the relay, but it badly interferes with measurements because I was not able to saturate its gate all over the range.
    So I sticked to the relay, even with its click-clacking noise, if I only had a reed relay at hand...
    The complete circuit is attached. It has no rail-to-rail reading ability, however. Although there is no upper limit other than supply voltage (and perhaps even more with appropriate voltage divider resistors), the POT command has an inherent limitation because it stops the internal timer when the voltage drops below 1.4 V at the input pin. So the smaller voltage we can read is slightly above that, my circuit measurement range was from 1.50 to 5.07 Volt.
    The measurements were pretty repetitive but far from linear. It took me some maths to regress a cubic equation that converts from bytes to Volts, and some more effort to cope with BS1 integer math limitations, but I ended up with a code that reproduces a Digital Volt Meter with an error of about 50 mV. And since it takes less than 30% of memory we can think of some practical applications.
    ' {$STAMP BS1}
    ' {$PBASIC 1.0}
    SYMBOL PotPin = 7 ' 10K resistor connected to P7 via a diode
    SYMBOL Scale = 87 ' scale value for test circuit
    SYMBOL measure = 6 ' switching device to voltage to be measured
    SYMBOL level = B2 ' storage of pot "level"
    SYMBOL V = W2 ' storage for Voltage conversion
    Main:
    LOW measure ' opens switch
    POT PotPin, Scale, level ' read external level and convert to hundreths of V
    V=100*level/224*level/249*level/197 ' cubic term +9.10090e-8*level^3
    V=-20*level/117*level/159/211+V ' quadratic term -1.27381e-6*level^2
    V=100*level/153*248/199+V ' linear term +8.14531e-3*level
    V=100*155/103+V ' constant term +1.50487
    level=V/100 ' integer part
    V=V//100 ' fractional part
    DEBUG CLS,"Input=",#level,".",#V," V" ' display voltage
    HIGH PotPin ' closes diode gate
    HIGH measure ' closes switch for next measure
    PAUSE 10 ' short delay to allow for charging
    END
    578 x 569 - 21K
