How can I use a binary bit pattern to set highs and lows on multiple pins? Easy
Hi,
I usually use the propeller, but am also trying to learn SX/B for projects where the propeller would be overkill. I mention the propeller because I can easily do the following in SPIN, but find myself stuck when attempting to do the equivalent on the SX.
I scanned through som previous forum posts without finding what I'm looking for.
I'm trying to set the highs and lows of 3 output pins using a binary bit pattern.
Is there an easy way to do this? Any help will be greatly appreciated.
Thanks in advance.
Merry Christmas
Example:
the output pins are RB.0, RB.1 and RB.2
#1
Binary_pattern = %101
The result I want based on this bit pattern is:
RB.0 high
PB.1 low
PB.2 high
#2
binary_pattern = %011
desired result:
RB.0 low
RB.1 high
RB.2 high
Using Spin the equivalent would be:
#1
Bit_pattern := %101
OUTA[noparse][[/noparse]RB0..RB2] := Bit_pattern
#2
Bit_pattern := %011
This post is a work of art. Variations in spelling and grammar are intentional, artistic endeavors that add value to all of mankind.
Thanks in advance.
Merry Christmas
Example:
#1
RB.0 high
PB.1 low
PB.2 high
#2
desired result:
RB.0 low
RB.1 high
RB.2 high
#1
Bit_pattern := %101
#2
Bit_pattern := %011
You can also use GETBIT and PUTBIT which are pin bit operators in the forthcoming SX/B 2.0, but essentially those high level commands do the same as above.
Thanks for the quick reply!
I'll study your example and try to figure it out.
B-
Post Edited (JonnyMac) : 12/26/2008 9:20:34 PM GMT
I appreciate the info, every little bit helps <no pun intended>
B-
