How can I use a binary bit pattern to set highs and lows on multiple pins? Easy — Parallax Forums
Brian218Brian218 Posts: 92
edited 2008-12-28 03:59 in General Discussion
I usually use the propeller, but am also trying to learn SX/B for projects where the propeller would be overkill. I mention the propeller because I can easily do the following in SPIN, but find myself stuck when attempting to do the equivalent on the SX.
I scanned through som previous forum posts without finding what I'm looking for.
I'm trying to set the highs and lows of 3 output pins using a binary bit pattern.
Is there an easy way to do this? Any help will be greatly appreciated.
Thanks in advance.
Merry Christmas
Example:
the output pins are RB.0, RB.1 and RB.2
#1
Binary_pattern = %101
The result I want based on this bit pattern is:
RB.0 high
PB.1 low
PB.2 high
#2
binary_pattern = %011
desired result:
RB.0 low
RB.1 high
RB.2 high
Using Spin the equivalent would be:
#1
Bit_pattern := %101
OUTA[noparse][[/noparse]RB0..RB2] := Bit_pattern
#2
Bit_pattern := %011
This post is a work of art. Variations in spelling and grammar are intentional, artistic endeavors that add value to all of mankind.
  • ZootZoot Posts: 2,227
    edited 2008-12-26 02:44
    Use the full port (i.e. RB or a symbolic equivalent), e.g.
    MyPort PIN RB OUTPUT ' RB.0 - RB.7 are outputs, addressed as "MyPort"
    myByte VAR Byte
    MyPort = %0000_0001  ' set just RB.0 high, the rest low
    MyPort = %1000_1000  ' RB.3 and RB7 high, rest low
    'masking and setting just some pins with AND and OR ...
    myByte = MyPort ' copy to work byte
    myByte = myByte & $F0 ' mask off all 4 low nib bits
    myByte = myByte | %1010 ' or to set .3 and .1 high
    MyPort = myByte ' copy back to port
    You can also use GETBIT and PUTBIT which are pin bit operators in the forthcoming SX/B 2.0, but essentially those high level commands do the same as above.
  • Brian218Brian218 Posts: 92
    edited 2008-12-26 04:16
    Zoot,
    Thanks for the quick reply!
    I'll study your example and try to figure it out.
    B-
  • JonnyMacJonnyMac Posts: 9,795
    edited 2008-12-26 14:42
    You can also do direct bit-to-bit copies when it's just a few pins; this is also helpful if they pins from source to destination are not aligned or contiguous.
    myPort.0 = myByte.0
    myPort.4 = myByte.1
    myPort.7 = myByte.2
    Post Edited (JonnyMac) : 12/26/2008 9:20:34 PM GMT
    Thanks JonnyMac!
    I appreciate the info, every little bit helps <no pun intended>
    B-
