fast switching relais
i want to switch whit the basic stamp a relais for 1000 V.
I want to do that realy fast, is there a switch witch can do that for me?
sory i'm a beginner in the electronics so to say, i come from a programmingbackground, so sorry for that, but still learning every day [noparse];)[/noparse]
thank you in advance
This discusses switching power for motors, solenoids, and relays using a Stamp and an external switching transistor or Darlington transistor array. The diagram on the last page shows the typical circuit. The details of the parts needed depend on the voltage and current being switched, but what's shown is typical for low power (6 - 15V and up to 1A).
thank you so much for your time!!
i did had 1 year electrnics but that's a long time ago, time to find my old schoolbooks again.
thank you so much!!
I have personally built a very slow and large HV relay for switching 12kV to charge a Marx bank. Was a major pain and had to be redesigned twice. It works quite well now though.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
like this
but then alot BIGGER
i want to swith the radiant into a capacitor/batterie
the spikes are about 700 V very fast
thank you so much for your answers!!
