spin variable types and manipulation
hi, this is my first post on these forums. im quite new to the propeller also. Im not new to microcontrollers and definately not to programming. I have some knowledge in C and it is my favourite programming language. that is where my problem begins.
About one week ago i started working with the propeller and im amazed by the technology! But im not yet amazed by SPIN. I mean i always get the stuff that i want to work but i find it kind of ugly. You have the "types" and they dont really make sense to me. Im too deep into C where variable types make like 40% of the whole biz.
Okay to get down to the point. I have a problem with string manipulation, or to say it like this im not really sure if my variable is a string hehe it just doesnt make much sense to me. I interfaced an RGM-2000 GPS receiver and it works great. To parse the NMEA code i use an object from the object exchange. Search for gps or gps vga. Basically the code is short and straight forward. It does exactly what i need, well almost.
There is this part:
VAR
long GPGGAa[noparse][[/noparse]20]
that long is filled in the readNMEA function and the time is returned here
pub time
return GPGGAa[noparse][[/noparse]0]
now in my main object i call time
and print it to my screen directly using a print function
it prints out something like that:
225510.313
that means the time is 22 hours, 55 minutes and 10 seconds and some miliseconds i dont care about.
Thats great but kind of unreadable! It's almost sad to me that i have to ask for help about this. In C it would be so easy to put some ":" or whatever between the digits but i dont get the spin code. I tried to find out in the code reference and the wiki but im stuck.
Is the time saved as a number (a long) or a string there?! since i can directly print it it must be a string. but then again why GPGGAa[noparse][[/noparse]0]? that makes no sense to me.
Thanks for any help. I hope i get to understand this soon. BTW im developing a "trip computer" for cars using the propeller.
There is this part:
VAR
pub time
225510.313
There is a C for the Prop ($100). I have no experience with it.
John Abshier
long GPGAa[noparse][[/noparse]20] an array of 20 longs
the time seems to be one long in that array, so the time function returns GPGAa[noparse][[/noparse]0], it returns one long value, basically a number. so now i print it using my printstr function BASICALLY now it should print only garble since its a long in terms of a number but it prints a number again, wth?! In C that simply would throw an error because a long is a number and a string is a string. You simply convert those and its done.
So I've got one long with the value 123544.388 for example, its just a floating point value BUT this time its the time in digits. I just need a function to convert this long to a character string and then i would get the elements from that array but right now its a number
John Abshier
In ANSI C it would look something like:
#include <stdio.h> int main(void) { char *myStr = "225510.313"; // test string (NMEA time) unsigned long GPGGAa[noparse][[/noparse]20]; // the array of pointers (as a long to show how it 'works' in the Propeller) GPGGAa[noparse][[/noparse]0] = (unsigned long)myStr; // store 'pointer' to the string in the first array element printf("%ul %s\n", myStr, myStr); // print out the original string's address and string data printf("%ul %s\n", GPGGAa[noparse][[/noparse]0], GPGGAa[noparse][[/noparse]0]); // print out the data using just the address stored in the array return 0; }Which prints:
This works similarly in SPIN. The program just stores the address of the string in the first element of the long array, much like how you would do it in SPIN. Of course C has much better ways of doing it (explicit pointer types, etc), but we are forcing the char pointer to fit in a long by casting it for this example. Notice how printing both the original string and the address work the same. You can even print out the pointer address (which shows that it doesn't really know about the variable type at this point).
To answer your question:
John Abshier's solution is almost exactly what you need. The only difference is you need to 'dereference' the pointer one more time. That is, you need to get the actual string that is located at that pointer before you can start forming the new string.
Something like this should work:
Post Edited (Harrison.) : 12/24/2008 4:59:55 PM GMT
consider that the whole SPIN-interpreter fits into ONLY 496 longs !!
I wanna see that C-dialect that is small like this
Any C on a PC just the typecasting routines will take more memory than zhe whole
SPIN-interpreter
If you want to have the comfort of C switch over to imagecraft C-compiler for propeller (100$)
or a PC104-module with a 486-processor for about 400$
OK back to SPIN.
GPGGAa[noparse][[/noparse]0] contains the POINTER to the time
I'm not sure but I guess the pointer points to a zero-terminated string.
In this case you can build a new formatted string out of the original string
For doing this take a look into the method str of FullDuplexSerial
PUB str(stringptr) '' Send string repeat strsize(stringptr) tx(byte[noparse][[/noparse]stringptr++])you have to code something like
another suggestion:
in the obex there is an object format wich can format strings in the printf-style
best regards
Stefan
that is the gps object im using. I need to have a look at that formatting object.
Ten-hour digit goes from 0 to 2················· ·-- 2 bits
One-hour digit goes from 0 to 9····················· 4
Ten-minute digit goes from 0 to 5················· ·3
One-minute digit goes from 0 to 9·················· 4
Ten-second digit goes from 0 to 5················· 3
One-second digit goes from 0 to 9················· 4
1/10 second digit goes from 0 to 9················ 4
1/100 second digit goes from 0 to 9··········· ····4
1/1000 second digit goes from 0 to 9········· ····4
Total, 32 bits.· This is not a common way of storing BCD, but it is most economical in a machine that suffers from storage poverty, and especially in one that serializes access to common memory in (a maximum of) 4-byte chunks.· Might the object have stored it that way?
· -- Carl, nn5i@arrl.net
