WIFI on a BS2
I had an interesting idea for a project. The wireless mic band is being limited by the FCC, so why not create VoIP mics? I can get A/D converters cheap, and routers are cheap. I am also a good enough programmer to write an app to do the mixing. The problem I run into is getting the mics on a network. I figure I can take sound output and·feed it to a BS2. The BS2 can handle creating the·network stream.·I want to take a BS2 and interface it with one of those USB wifi adapters you can get cheap at any major electronics store. The problem is, I am not sure how to do it. I am looking at the FT232 USB to serial converter, but I am not sure if it will work. Has anyone got a stamp to interface successfully with WIFI or am I trying to do the impossible here?
thanks in advance
thanks in advance
You could use a Propeller which can do the ADC itself and can handle the Ethernet (see ucontroller.com/documentation/PropNICDoc.html and www.deepdarc.com/ybox2/) although you'd have to write your own VoIP protocol stack.
