Having problems with COUNT
Capt. Quirk
' {$STAMP BS2}
' {$PBASIC 2.5}
cycles VAR Word
DO
COUNT 15, 100, cycles
cycles = cycles * 10
DEBUG HOME, "Frequency = ", DEC5 cycles, " Hz"
LOOP
Nice and simple program from the Parallax "[font=Arial,Bold size=5][font=Arial,Bold size=5]IR Remote for the Boe-Bot" that goes along with the attached schematic for verifying the frequency of a 555 timer. The program doesn't count anything. Replace COUNT with PULSIN and I get data. I have no problem flashing an red colored LED with the 555, but·I can't seem to measure it with the current program. [/font][/font]
[font=Arial,Bold size=5][font=Arial,Bold size=5][/font][/font]
[font=Arial,Bold size=5][font=Arial,Bold size=5]I have also tried taking the led out of the circuit and driven the 555's pin4 high, with no success.[/font][/font]
[font=Arial,Bold size=5][font=Arial,Bold size=5]With nothing hooked up, COUNT does tend to float a bit and show numbers, but as soon as it's conected, nothing.[/font][/font]
[font=Arial,Bold size=5][font=Arial,Bold size=5]Any ideas?[/font][/font]
[font=Arial,Bold size=5][font=Arial,Bold size=5]Bill···[/font][/font]
' {$PBASIC 2.5}
cycles VAR Word
DO
LOOP
What "flavor" of BS2 are you using?· ...BS2,BS2e,BS2sx,BS2p,BS2pe, BS2px, etc.
And what frequency (ballpark) are you trying to read?
Beau Schwabe
IC Layout Engineer
(1) Your schematic shows (apparently) a connection to BS2 P7 (or maybe pin 7, which is P2), but your program counts P15.
(2) You say you can flash a LED. If you can see it flash, it's probably flashing slower than 15 times per second. Your COUNT statement says to count for 1/10 second. How many counts did you expect in 1/10 second?
· -- Carl, nn5i@arrl.net
I started with pin 7, changed the program to pin 15, because it's easier to use. Also I thought I would need to set it the pin as an Input to work with COUNT and that didn't seem to help.
I created another program using PULSIN and a 100 ms Pause statement, and I was getting readings around 210. Maybe I should be satisfied with that, but I was trying to figure out what I did wrong with the COUNT statement.
Bill
I am going to try and use ViewPort to measure the output, does anybody know if I need to use anything more than inline 1K resistor to test the signal with a Propeller?
Bill
Post Edited (Capt. Quirk) : 12/19/2008 11:47:44 PM GMT
