Assistance in attached robot schematic — Parallax Forums
jcoloniasjcolonias Posts: 31
edited 2008-12-16 15:03 in Robotics
Hi;
· I would very much appreciate in your assisting in varifying that the attached
schematic is correct.
I intend to connect two HB 25s with two 12v·DC motors, well within the power specs. The MCU
that I have would probably be the Propeller or the BS2p 40 ( I have both). I intend to have
separate power sources for the motors and the MCU, with the switching arrangement shown.
I have checked the diagram and it seems OK, but I will feel more comfortable if some one gives it
a check out.
I intend to connect a few sensors and to the MCU and once I have it ruuning, I will post some pictures.
Thaniks, John
    edited 2008-12-16 02:14
    I made some modifications.· My practice is to always leave GND/COM/RTN connected throughout.
    Accept or Reject, your choice.
    537 x 428 - 27K
  • GWJaxGWJax Posts: 267
    edited 2008-12-16 02:21
    Good corrections PJ all grounds must be connected together to work with all components. the powers sources must work as one when the ground is conserned.
    Jax
    If a robot has a screw then it must be romoved and hacked into..
  • iDaveiDave Posts: 252
    edited 2008-12-16 03:57
    I've been wondering this. What tool is used to draw simple schematics like above?
    "THE ONLY TRUE WISDOM IS IN KNOWING YOU KNOW NOTHING." - SOCRATES
  • willy1067willy1067 Posts: 107
    edited 2008-12-16 04:16
    Paint Brush... simple and easy, even for a cave man. lol
    Fernando Gomez
    ·http://pinellas-sign-manufacturer.com
    Never compare yourself with anyone else, there will always be someone bigger·or·smaller·than you.
  • jcoloniasjcolonias Posts: 31
    Gentlemen:
    Thank you very much.
    PJ Allen, your suggestions are excellent and I will follow.
    iDave, believe it or not I used Microsoft's Word!
    GWJax, thank you for agreeing with PJ Allen.
    I will post some images when the robotd runs around.
    John
