Assistance in attached robot schematic
Hi;
· I would very much appreciate in your assisting in varifying that the attached
schematic is correct.
I intend to connect two HB 25s with two 12v·DC motors, well within the power specs. The MCU
that I have would probably be the Propeller or the BS2p 40 ( I have both). I intend to have
separate power sources for the motors and the MCU, with the switching arrangement shown.
I have checked the diagram and it seems OK, but I will feel more comfortable if some one gives it
a check out.
I intend to connect a few sensors and to the MCU and once I have it ruuning, I will post some pictures.
Thaniks, John
a check out.
Thaniks, John
Accept or Reject, your choice.
Jax
If a robot has a screw then it must be romoved and hacked into..
"THE ONLY TRUE WISDOM IS IN KNOWING YOU KNOW NOTHING." - SOCRATES
Fernando Gomez
·http://pinellas-sign-manufacturer.com
Never compare yourself with anyone else, there will always be someone bigger·or·smaller·than you.
Thank you very much.
PJ Allen, your suggestions are excellent and I will follow.
iDave, believe it or not I used Microsoft's Word!
GWJax, thank you for agreeing with PJ Allen.
I will post some images when the robotd runs around.
John
