Sony 5 volt 2000 milliamp Power Supply I would also like some one from Paralla
These are switching power supplies
It says 5.00 volts but when you put a volt meter to it it read 5.47 volt even with a load on them
Could·I use these to power a Basic Stamp OEM board with out the on board regulator
I was thing about using a 5 volt zener diode·and powering the Basic Stamp with that will this work
I would also like some one from Parallax to chime in as well
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 12/13/2008 1:10:49 AM GMT
··Thanks for any·
·that you may have and all of your time finding them·
Sam
First make sure your voltmeter is reading correctly. With your BASIC Stamp or BOE connected in the usual way to an unregulated Vin supply, measure the voltage on Vdd. Is it 5V? If so, your voltmeter is okay, so try the trimpot. If you can't find one, add a 1N4001 rectifier to the power supply's output. That will drop the voltage by at least 0.6V to a safe level. (It'll be lower than 5V, but still high enough. Be sure to measure it first before connecting a Stamp!)
Thank you for your help with this
I did open one of them it dose not have a trim pot in it
First make sure your voltmeter is reading correctly. With your BASIC Stamp or BOE connected in the usual way to an unregulated Vin supply, measure the voltage on Vdd. Is it 5V? If so, your voltmeter is okay, so try the trim pot.
I have done this part before and I know that the meter is right but I will make sure of it with another meter
··Thanks for any·
Sam
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 12/12/2008 7:01:34 AM GMT
Thank you for your reply· that will help a lot
··Thanks for any·
Sam
Since Amps X Volts = Watts and E = I X R, you might estimate what size 1/2 watt resistor won't burn up.
.5 watts = 5.5 volts x amps. A .5 watt resistor can handle at most 1/11 amps [noparse][[/noparse]let's say 1/12 for safety and call it 83 millamps.]
So... R = 5.5 volts/.083 amps = 66 ohms minmun.
But if you use a 1/4 watt resistor it would have to be double or 132ohms minmun.
Anything higher will work safely. Anything lower will get hotter and burn up.
It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
Leon
