Sony 5 volt 2000 milliamp Power Supply I would also like some one from Paralla — Parallax Forums
sam_sam_samsam_sam_sam Posts: 2,286
edited 2008-12-16 16:59 in General Discussion
These are switching power supplies
It says 5.00 volts but when you put a volt meter to it it read 5.47 volt even with a load on them
Could·I use these to power a Basic Stamp OEM board with out the on board regulator
I was thing about using a 5 volt zener diode·and powering the Basic Stamp with that will this work
I would also like some one from Parallax to chime in as well
··Thanks for any·idea.gif·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 12/13/2008 1:10:49 AM GMT
    edited 2008-12-12 00:13
    There might be a trimpot (adj)·inside, if you can open the case.
    edited 2008-12-12 00:22
    Forget the zener.
    First make sure your voltmeter is reading correctly. With your BASIC Stamp or BOE connected in the usual way to an unregulated Vin supply, measure the voltage on Vdd. Is it 5V? If so, your voltmeter is okay, so try the trimpot. If you can't find one, add a 1N4001 rectifier to the power supply's output. That will drop the voltage by at least 0.6V to a safe level. (It'll be lower than 5V, but still high enough. Be sure to measure it first before connecting a Stamp!)
    edited 2008-12-12 01:02
    PJ Allen & Phil
    Thank you for your help with this
    I did open one of them it dose not have a trim pot in it
    First make sure your voltmeter is reading correctly. With your BASIC Stamp or BOE connected in the usual way to an unregulated Vin supply, measure the voltage on Vdd. Is it 5V? If so, your voltmeter is okay, so try the trim pot.
    I have done this part before and I know that the meter is right but I will make sure of it with another meter
    Sam
  • LeonLeon Posts: 7,620
    edited 2008-12-12 06:52
    5.47 V is probably within spec. for most 5V designs, including the BS2. PICs generally have a recommended Vdd of up to 5.5V.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Post Edited (Leon) : 12/12/2008 7:01:34 AM GMT
    edited 2008-12-13 01:06
    Leon
    Thank you for your reply· that will help a lot
    Sam
    edited 2008-12-14 19:06
    The 5.47 is likely high due to no load. If you add a load resistor, it should pleasantly drop.
    Since Amps X Volts = Watts and E = I X R, you might estimate what size 1/2 watt resistor won't burn up.
    .5 watts = 5.5 volts x amps. A .5 watt resistor can handle at most 1/11 amps [noparse][[/noparse]let's say 1/12 for safety and call it 83 millamps.]
    So... R = 5.5 volts/.083 amps = 66 ohms minmun.
    But if you use a 1/4 watt resistor it would have to be double or 132ohms minmun.
    Anything higher will work safely. Anything lower will get hotter and burn up.
    It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
    Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
    edited 2008-12-14 19:25
    Those switching PSs have good regulation, a load resistor won't do much. 5.47 V is probably within the usual manufacturing tolerance for such units.
    Leon
    Then, if one is worried about too much volts, inserting one diode will drop the voltage from 0.3 volts to 0.7 depending on the type. Just be sure it can handle 2 amps of current.
